First Boot HDMI/USB problem
Hi all, I just got my pine A64+ 2GB I followed the steps on flashing multiple OS and here are my results:
archlinux-xfce-pine64-20181104
xenial-pine64-bspkernel-20161218-1
xubuntu-xenial-mate-20161215-longsleep-pine64-8GB
I connect my pine64 via hdmi Ethernet and a usb keyboard. It successfully loads into the login page but my keyboard does not power up. I'm stuck at the login page and I can't do anything.
I tried android-ver6.0-20170112-pine64-32GB.img as well and for this OS, the HDMI output does not show anything.
Any advice on how to make it work?
(11-18-2018, 02:28 AM)reefer Wrote: Hi all, I just got my pine A64+ 2GB I followed the steps on flashing multiple OS and here are my results:
1. There is a 4 pin jumper pin area on top of EXT connector, please make sure the you either connect to :power" or "batt", this jump route power to USB port.
2. Please plug in your USB keyboard to PC or notebook to confirm that your keyboard still function.
3. Make sure your 32GB microSD card is good performance one (class 10 type, perfer Samsung or Sandisk), Android demand high SD read access.
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 88 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  New RockPro64 Power Up Problem enorbet2 7 5,021 10-28-2023, 12:08 PM
Last Post: dkebler
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,188 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,624 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,587 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,710 08-07-2022, 10:47 AM
Last Post: commiecam
  dependency problem cerno 4 4,947 05-07-2021, 08:18 AM
Last Post: cerno
  How to boot from SD card on pinebook pro linux123 3 6,121 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,259 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,163 10-18-2020, 01:41 PM
Last Post: toiny
