Pinebook Ubuntu XFCE screen resolution options
Currently my 11.6" Pinebook only has 1920x1080 screen resolution and I can't connect to another monitor via the hdmi cable. Is there a solution for this? Thanks
(11-11-2018, 12:04 PM)Fox7799 Wrote: Currently my 11.6" Pinebook only has 1920x1080 screen resolution. Do we wait for a multi-resolution fix or is there a solution now? I see there is a sunxi-disp-tool fix. Would that work on Ubuntu XFCE? Thanks
If you go into the fonts settings and change the "force font DPI" to 120 (from the default 96), it makes everything a lot easier to see and read. Wink
(11-11-2018, 12:04 PM)Fox7799 Wrote: Currently my 11.6" Pinebook only has 1920x1080 screen resolution and I can't connect to another monitor via the hdmi cable. Is there a solution for this? Thanks
sddm is the default display manager. Would lightdm or gdm3 give us multiple display options and allow hdmi mirroring on a connected monitor? I installed lightdm and gdm3 but apparently have had no luck in switching to them and don't want to mess up my laptop. Any help would be appreciated. Thanks
  DietPi OS for Pinebook MichaIng 3 5,472 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 61,359 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 935 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 725 07-10-2023, 07:44 AM
  Change console resolution (Armbian/bookworm) jcgraybill 1 1,039 06-22-2023, 01:31 PM
Last Post: jcgraybill
  Pinebook no longer boots rjtanner 12 3,742 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,250 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,908 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,284 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,837 01-20-2021, 11:18 AM
