are there any plans for SATA to use 2/4 lanes PCI-E ?
I had the card for 2 weeks was working perfect until today just die,
lspci -V gave me no reply waiting for exchange from Amazon in the meantime put back my old card
Kind of strange since, I made sure my case was always below 40C
and for people wondering I supplied power to the other drive by adding an other Pine sata power cable.
(11-21-2018, 06:27 PM)Girbur Wrote:
(11-18-2018, 09:13 PM)romtorwator Wrote: not quite, You have chosen with a different chip, Marvell 88SE9215, he is slower because uses one lane PCI-E
we are talking about chip Marvell 88SE9235 (non RAID) or Marvell 88SE9230 (Raid), using two PCI-E lanes.
https://www.amazon.com/CREST-Drive-Contr...3AIO+Crest
It works right out of the box, not doing anything in the system (I personally did not do anything).
Yes
Ma question did you put 4 drives ?
since myself  I already got 2 X 3.5 how would you feed the 5 volts to the 2 X 2.5 ? what do you think wold be the best solution?
Safest to risky in order
1-external 5 volts supply
2-an other Pine sata power cable https://www.pine64.org/?product=rockpro6...ata-drives
taking the 5volts from the existing Pine sata power cable
4- getting 5 volt power from pin 4 and 6 of PI2 bus?
I'm probably asking for trouble but so far, so good. [Somebody stop me!!! Big Grin ]
I'm using one of these cards with a Marvel 9215 chipset. I've got the 2-2.5 drives in the RockPro NAS case populated with SSDs as my media storage (software RAID 1), and then using this kit here I've converted the 3.5" bay to house one additional SSD for containers and stuff.
I am using an EMMC chip for my OS, but other than that the device is headless and consumes ~10Watts (based on an initial reading only).
I'm sure someone will point out why this is a bad idea but so far so good!
  Which SATA card should I use my NAS server RAID5 Louysa 3 916 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 568 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 447 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,579 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,928 12-18-2022, 06:25 PM
Last Post: heyghoge
  Existings disks and using a StarTech SATA Controller jkugler 1 2,090 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  Rockpro64 Sata Card kills itself jerry110 33 44,474 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 2,992 09-15-2021, 12:46 PM
Last Post: corax
  Won't boot with SATA card rjzak 4 5,777 01-09-2021, 05:56 PM
Last Post: kuleszdl
  SATA issues machina 25 33,662 10-16-2020, 12:16 PM
Last Post: lrb
