First usable Armbian image!
Information
Current nightly from Armbian is pretty darn usable with DVFS, temperature sensor, Ethernet and HDMI on mainline: https://dl.armbian.com/pineh64/Debian_st...nightly.7z
[edit] Apart from Armbian (Igor, et al) credit making this build happen goes to MoeIcenowy; Jernej; and Wink from BU3
i already try this image : this is my result :
- ethernet work but only in 100 M not 1000M
- Usb3 is working ( didn't work in the other version ) : but speed limit is 40 mo /s
- Hdmi working on the dev version .
So good stuff working client application , not yet for server purpose, but it's going useable now.
(08-09-2018, 01:17 PM)Dark26 Wrote: i already try this image : this is my result :
GbE seems fine to me, haven't tested USB 3.0 yet (or am I misreading the output - not versed in iperf3):
lukasz@Mint18PC ~ $sudo iperf3 -c 192.168.1.85
Connecting to host 192.168.1.85, port 5201
[  4] local 192.168.1.70 port 33780 connected to 192.168.1.85 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec   114 MBytes   953 Mbits/sec    0    532 KBytes
[  4]   1.00-2.00   sec   105 MBytes   881 Mbits/sec   36    362 KBytes
[  4]   2.00-3.00   sec  97.7 MBytes   819 Mbits/sec   13    322 KBytes
[  4]   3.00-4.00   sec  97.6 MBytes   819 Mbits/sec   12    351 KBytes
[  4]   4.00-5.00   sec  97.4 MBytes   817 Mbits/sec    3    387 KBytes
[  4]   5.00-6.00   sec  97.5 MBytes   818 Mbits/sec    6    409 KBytes
[  4]   6.00-7.00   sec  98.8 MBytes   828 Mbits/sec    5    427 KBytes
[  4]   7.00-8.00   sec   111 MBytes   929 Mbits/sec    0    430 KBytes
[  4]   8.00-9.00   sec   111 MBytes   928 Mbits/sec    0    431 KBytes
[  4]   9.00-10.00  sec   103 MBytes   864 Mbits/sec   15    386 KBytes
[  4]   0.00-10.00  sec  1.01 GBytes   866 Mbits/sec   90             sender
[  4]   0.00-10.00  sec  1.00 GBytes   862 Mbits/sec                  receiver
lukasz@Mint18PC ~ $sudo iperf3 -c 192.168.1.85 -R
Reverse mode, remote host 192.168.1.85 is sending
[  4] local 192.168.1.70 port 33998 connected to 192.168.1.85 port 5201
[  4]   0.00-1.00   sec   103 MBytes   861 Mbits/sec
[  4]   1.00-2.00   sec   104 MBytes   871 Mbits/sec
[  4]   2.00-3.00   sec   104 MBytes   873 Mbits/sec
[  4]   3.00-4.00   sec   104 MBytes   872 Mbits/sec
[  4]   4.00-5.00   sec   104 MBytes   869 Mbits/sec
[  4]   5.00-6.00   sec   104 MBytes   873 Mbits/sec
[  4]   6.00-7.00   sec   104 MBytes   872 Mbits/sec
[  4]   7.00-8.00   sec   103 MBytes   866 Mbits/sec
[  4]   8.00-9.00   sec   104 MBytes   872 Mbits/sec
[  4]   9.00-10.00  sec   104 MBytes   873 Mbits/sec
[  4]   0.00-10.00  sec  1.02 GBytes   873 Mbits/sec    0             sender
[  4]   0.00-10.00  sec  1.01 GBytes   870 Mbits/sec                  receiver
i have to try again. again then
i alsa tested with iperf 3 and the car dis detect 100 M/
i tried to force 1000 with ethool but then no network at all.
can you do a ethtoool eth0 ?
Quote:root@pineh64:~# ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes:   10baseT/Half 10baseT/Full
                        100baseT/Half 100baseT/Full
                        1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes:  10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes:  10baseT/Half 10baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: d
Wake-on: d
Current message level: 0x0000003f (63)
       drv probe link timer ifdown ifup
Link detected: yes
root@pineh64:~#
Quote:root@pineh64:~# iperf3 -c 192.168.1.100
Connecting to host 192.168.1.100, port 5201
[  4] local 192.168.1.72 port 42872 connected to 192.168.1.100 port 5201
[  4]   0.00-1.00   sec  12.1 MBytes   101 Mbits/sec    0    137 KBytes
[  4]   1.00-2.00   sec  11.2 MBytes  94.4 Mbits/sec    0    144 KBytes
[  4]   2.00-3.00   sec  11.2 MBytes  94.4 Mbits/sec    0    144 KBytes
[  4]   3.00-4.00   sec  11.2 MBytes  94.4 Mbits/sec    0    150 KBytes
[  4]   4.00-5.00   sec  11.2 MBytes  94.4 Mbits/sec    0    150 KBytes
[  4]   5.00-6.00   sec  11.2 MBytes  93.8 Mbits/sec    0    150 KBytes
[  4]   6.00-7.00   sec  11.4 MBytes  95.4 Mbits/sec    0    173 KBytes
[  4]   7.00-8.00   sec  11.2 MBytes  94.4 Mbits/sec    0    173 KBytes
[  4]   8.00-9.00   sec  11.2 MBytes  94.4 Mbits/sec    0    173 KBytes
[  4]   9.00-10.00  sec  11.2 MBytes  93.8 Mbits/sec    0    173 KBytes
[  4]   0.00-10.00  sec   113 MBytes  95.0 Mbits/sec    0             sender
[  4]   0.00-10.00  sec   112 MBytes  94.2 Mbits/sec                  receiver
iperf Done.
Here:
lukasz@pineh64:~$ sudo ethtool eth0
Settings for eth0:
                                         1000baseT/Full
    Link partner advertised pause frame use: Symmetric
    Speed: 1000Mb/s
    Duplex: Full
    Port: MII
    PHYAD: 1
    Supports Wake-on: d
    Wake-on: d
    Link detected: yes
thanks.
Maybe something broken with my board...
(08-09-2018, 03:54 PM)Dark26 Wrote: thanks.
How about wires or network switch ? Or something simplier ? Sure its the same image ? I just fetched it today, and seems like Igor updated the image just today ...
i tried directly on the switch, it's the same. I try with the android image and it's only 100 m like in armbian.
i have the lastest image
(08-09-2018, 04:14 PM)Dark26 Wrote: i tried directly on the switch, it's the same. I try with the android image and it's only 100 m like in armbian.
kernel 4.18, correct ?
Yes .
i try both image by the way, same issue.
  Armbian 22.02 Release Announcement TRS-80 0 3,432 02-28-2022, 05:07 PM
Last Post: TRS-80
  Usable headless server distro altonian64 1 4,603 12-15-2021, 09:32 AM
  Armbian: Ethernet port goes down shortly after successful configuration. Kawayuppie 1 6,072 04-16-2021, 05:41 AM
Last Post: evilbunny
  LibreELEC testing image for Pine H64 Luke 7 17,848 06-12-2020, 02:38 AM
Last Post: p1x3l3d
  Unable to boot any armbian linux vicsanca 6 12,472 10-17-2019, 12:08 PM
Last Post: JGwinner
  Any informations about Linux image? CoMcE 41 83,782 02-27-2019, 10:40 AM
Last Post: NicoD
