Any informations about Linux image?
Hello all,
my PineH64 reached me now. :-)
I want to ask, when do you plan to release a bootable linux image?
Also I want to ask, if there are any informations about creating
a bootable Linux myself, with the kernel which had been released for the H6?
I never compiled a kernel myself, but I wanna try and believe, I  could
be able to do this with some more informations.
Maybe there is a tutorial existing for another board?!
Regards, CoMcE
Hi, I currently run Arch Linux with mainline (4.15.3) Linux plus patches from linux-sunxi on top on my PineH64, that makes USB2, USB3 and GbE work, but H6 support in mainline has not officially started yet... As for the 4.9.x BSP Allwinner has released, it's still in beta and as far as I could tell the kernel at least boots and has most of the drivers for H6...
H6 mainline Linux branches I use:
https://github.com/Icenowy/arm-trusted-f...ree/h6-smp
https://github.com/Icenowy/u-boot/tree/h6-dram
https://github.com/Icenowy/linux/tree/h6-init
for rootfs I use anarsoul's Arch Linux mainline images:
https://github.com/anarsoul/linux-build/releases
Relevant patch series for mainline are atm:
[PATCH 0/5] Add 3GiB DRAM support to 64-bit Allwinner SoCs
https://groups.google.com/forum/#!search...i2auihBAAJ
[PATCH v2 0/6] Initial Allwinner H6 support
https://groups.google.com/forum/#!search...eDeQ8mCwAJ
The Allwinner 4.9 Linux BSP can be found at:
https://github.com/Allwinner-Homlet?tab=repositories
if you want to have a go at that...
Thanks for the info, I've gotten so far as getting u-boot working, still trying to get the kernel to load.
Thank you very much!
I will have a look at all of this stuff this weekend! Smile
Have a nice day!
Regards
Thank you, I will give it a try soon.
Just to better understand, Xalius, which defconfig file you use on u-boot and kernel?
Thanx
for u-boot there's pine_h64_defconfig
i just used the arm64 defconfig for the kernel but I haven't gotten it working yet
I use https://github.com/Icenowy/linux/blob/h6.../defconfig , #worksforme :-)
(02-28-2018, 07:38 PM)xalius Wrote: I use https://github.com/Icenowy/linux/blob/h6.../defconfig , #worksforme :-)
well, i'm pretty new to this stuff, I built an Image but i'm not sure what to do with it, i tried making it a uImage but when I try to load it it just gets hung up at starting kernel.  Maybe i just missed something or there's another way i should be trying to boot it.
Xalius,
great job, really.
Boot and kernel runs fine.
In my environment I've enabled BLK_DEV_RAM in the kernel defconfig, and I booted a very basic buildroot file system.
Thank you so much, there's a coffee in Italy for you Cool
Regards
Filippo
  LibreELEC testing image for Pine H64 Luke 7 19,840 06-12-2020, 02:38 AM
Last Post: p1x3l3d
Information First usable Armbian image! Luke 19 43,775 04-02-2020, 04:03 AM
Last Post: as365n4
  Looking for Linux decoder/encoder API in H6 as well as any transcoding example gojustingo 1 6,326 12-17-2019, 03:36 AM
Last Post: xalius
  Unable to boot any armbian linux vicsanca 6 14,042 10-17-2019, 12:08 PM
Last Post: JGwinner
