AMENDED: OpenBSD, GigE Adapters/Chipsets, and ROCK64 STEREO AUDIO DAC ADD-ON BOARD
I see that OpenBSD's man pages indicate compatibility with various GigE chipsets, but Asix AA88179 is not among them.
(1) Should an Asix AA88179 GigE with and/or without a 3-port USB 3.0 hub work on OpenBSD?
Amendment: man usb shows
axen(4)ASIX Electronics AX88179 10/100/Gigabit USB Ethernet device
so, my question is about both GigE and the hub working (well) together.
(2) Does the 100BT of the audio dac add-on card work on OpenBSD?
Amendment: From
10/100Mbps MegJack on Audio DAC POT board Datasheet - http://files.pine64.org/doc/rock64/DGKYD...6GWA1D.pdf
I see ethernet as merely a feed-through from the board, but my original question remains.
(3) If unknown, shouldDoes the audio of the audio dac add-on card work on OpenBSD?
(4) That is, what driver does it use?
(5) And, worth a mention, does its audio work on OpenBSD?
(4) Can you specify other solutions involving USB 3.0 hubs with GigE?
(2) Haven't tried that yet.
(3) The I2S device ES9023 from the Audio DAC board is currently not supported by OpenBSD. So it doesn't work.
  Netbds10.0 on Rock64 not booting Ingen 12 21,484 05-20-2024, 09:08 AM
  Tutorial: Install OpenBSD on ROCK64 media board krjdev 31 70,264 04-29-2023, 04:32 AM
Last Post: newestssd
  OpenBSD 6.7 microSD card image krjdev 4 14,594 05-31-2020, 12:46 PM
Last Post: krjdev
  Rock64 ethernet not working during install OpenBSD Enig123 4 12,289 05-25-2020, 02:29 PM
Last Post: Enig123
Information NetBSD for Rock64 Luke 4 13,492 01-14-2020, 10:19 PM
Last Post: fmotsch
  OpenBSD: GPIO with the I2C device PCF8574(A) krjdev 0 6,306 08-09-2018, 06:41 AM
Last Post: krjdev
