super fast desktop experience, but youtube issue
installed the LXDE version and ran the following lines.
$ sudo apt update
$ sudo apt-get install linux-image-4.4.132-1083-rockchip-ayufan-gfd3f12ca5fae
video plays at correct speed with sound.
However DRM video content is not working.
went into firefox and enabled DRM the hard way because the options are not showing. I'll have to find the instructions to do this but you have to go into the config and force some options on.
installed libavcodec-extra with the following line
sudo apt install libavcodec-extra
if this is failing to install, reboot. netflix seems to break the internet for somethings when it crashes
I'm just not sure what to do after this. It seems like widevine cdm is still missing but firefox is suposed to go get that itself. chromium is also missing widevine.
I do have an "OpenH264 Video Codec provided by Cisco Systems, Inc" that says it will be installed shortly.
(08-21-2018, 02:51 AM)Firesped Wrote: installed the LXDE version and ran the following lines.
$ sudo apt update
any luck with with DRM content and Widevine?  I am stuck at the same spot
Maybe this helps, solved my problem, videos running at regular speed now:
https://forum.pine64.org/showthread.php?tid=6545
(08-03-2018, 10:55 AM)frewind Wrote:
(07-31-2018, 03:40 PM)boudiicca Wrote:
(07-31-2018, 07:48 AM)dukla2000 Wrote:
(07-31-2018, 06:31 AM)steamiestoyster Wrote: removing pulseaudio fixed the video playback speed. Now to get the sound working...
First check which card the HDMI is (on RP64 its card 2), then set ~/.asoundrc accordingly. Mine are below.
$ aplay --list-devices
**** List of PLAYBACK Hardware Devices ****
card 0: rockchipes8316c [rockchip,es8316-codec], device 0: ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: ROCKCHIPSPDIF [ROCKCHIP,SPDIF], device 0: ff870000.spdif-dit-hifi dit-hifi-0 []
  Subdevices: 1/1
card 2: rkhdmidpsound [rk-hdmi-dp-sound], device 0: HDMI-DP multicodec-0 []
  Subdevices: 1/1
chris@rockpro64:~$ cat .asoundrc
pcm.!default {
    type hw
    card 2
ctl.!default {
    type hw
    card 2
Yep...removing pulseaudio and setting the .asoundrc as per.....sorted....cheers!
heads up.....a fix is coming in the next kernel...should sort it permanently.
Followed the instruction, video now play at the correct speed, but still no sound Sad
sudo apt-get remove --purge pulseaudio
rock64@rockpro64:~$ cat .asoundrc
pcm.!default {
    type hw
    card 2
ctl.!default {
    type hw
    card 2
rock64@rockpro64:~$ aplay --list-devices
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
fixed the speed issue for me.  No audio through the headphone jack however.  I really need that to consider this project a success.
Big Grin Feature Complete Debian Desktop Release Mrfixit2001 158 179,931 05-29-2021, 04:05 AM
Last Post: twilite
  UART4 in Debian Desktop Release of Mrfixit2001 Gienek 1 2,835 05-19-2020, 02:47 AM
Last Post: Gienek
  Release 0.9.14 Ubuntu Mate desktop, LXDE, OMV, Docker CE (container) Luke 1 3,322 12-10-2019, 01:30 PM
Last Post: Helium75
Exclamation eMMC boot issue jwillmer 0 2,026 07-19-2019, 03:16 PM
Last Post: jwillmer
  computelibrary build issue with latest ubuntu 18 image rahulsharma 0 1,724 07-08-2019, 09:25 AM
Last Post: rahulsharma
  issue with kodi freezing randomly Slam 3 3,906 05-24-2019, 03:53 PM
Last Post: mknawabi
  Desktop battlenut 8 9,477 11-18-2018, 06:13 PM
Last Post: evilbunny
  Ubuntu Bionic LXDE Desktop /w Firefox and TightVNC stability HenryBenry 4 5,245 10-11-2018, 04:33 AM
Last Post: HenryBenry
  Issue with hwmon - Fan Stop after logout-Login tuxd3v 1 2,443 09-22-2018, 08:49 AM
Last Post: tuxd3v
  RockPro Wireless+Bluetooth Issue - Linux (ayufan 0.7.8 and previous) JeffD 23 28,090 09-16-2018, 12:08 AM
Last Post: romtorwator
