Compiling android kernel
Hey guys!
I need to change a few lines of code in the android kernel. I'm using this build but can't seem to find the kernel sources used to compile it. I tried to compile these sources up to the 3.10.104 merge tag but I get a lot of compilation errors. What gcc version should I be using? And once I compile the kernel how do I flash it to the rock64? Do I just use the compiled Image file as the kernel.img in AndroidTool or do I have to package it somehow?
Thanks!
(06-12-2018, 04:38 AM)ddaarrius Wrote: Hey guys!
Thanks!
ayufan is the best one to answer most of your questions. All I can say is that the build is done inside this docker container as instructed by this Jenkinsfile. Hopefully perusing those two files will give you an idea as to what is going on.
Thank you very much, this seems to be exactly what I need, I'll try it out soon.
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,277 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,034 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,559 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,621 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,026 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,507 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,023 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,581 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,734 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,818 09-09-2020, 08:44 AM
Last Post: BowerR64
