wifi dongle
I received this week my rock64 sbc and i installed ubuntu with etcher from image file: xenial-mate-rock64-0.5.5-136-arm64.img.xz. This gives a system version 16.04.3LTS with a kernel 4.4.77-rockchip-ayufan-136aarch64.
I also bought this wifi dongle (https://www.pine64.org/?product=usb-wifi...for-rock64), but i don't succed to make it working. It is well detected by the sbc (from lsusb output). Even after executing the command "sudo iw reg set FR" (i am in France), i don't succed to configure an internet connection with this wifi dongle.
Someone can help?
regards
(05-30-2018, 04:54 AM)pas059 Wrote: I received this week my rock64 sbc and i installed ubuntu with etcher from image file: xenial-mate-rock64-0.5.5-136-arm64.img.xz. This gives a system version 16.04.3LTS with a kernel 4.4.77-rockchip-ayufan-136aarch64.
does it show up in ifconfig -a ? or lsmod | grep 8188 ?
hi evilbunny
thanks for your reply
lsmod | grep 8188 gives 8188eu 1613824 0
and ifconfig - a lists 4 devices:
eth0 .... my GigE interface
lo...........
p2p0.............
wlx0013ef8043ec ................. which is the device selceted (there was one choice) )when i added a wifi connection.
As i am a beginner on ubuntu, i suppose/hope that this is my parameterization of the wifi connection that is wrong, but as when i added a wifi connection ubuntu suggested nothing......
Any idea ?
hi,
that's ok now, this works perfectly. It was my fault. I did not setup the wifi connection by the good way: i was using the 'Network connections' dialog rather than simply the wifi icon which was masked . In fact, it's too easy, don't laught at me please.
  gstreamer unable to process dvbsrc from ATSC tuner dongle grkblood13 1 4,779 08-31-2019, 09:01 PM
Last Post: grkblood13
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,619 03-26-2019, 07:28 PM
Last Post: Poincare
  Can't connect to wifi on a Rock64 SuperSaiyanCaleb 2 6,885 12-18-2018, 11:51 PM
Last Post: SuperSaiyanCaleb
Lightbulb Wifi problem Nether494 13 28,485 11-28-2018, 01:48 PM
Last Post: Nether494
  8812au wifi driver OS pane 9 19,114 11-19-2018, 02:46 AM
Last Post: pane
  WiFi on Armbian problem scalextrix 14 29,549 09-08-2018, 01:13 AM
Last Post: scalextrix
  OMV wifi setup (driver issue) six9 0 3,982 07-25-2018, 03:34 PM
Last Post: six9
  How can I get a driver to support my USB wifi dongle Rocklobster 4 9,842 04-19-2018, 12:55 PM
Last Post: Rocklobster
  alpha wifi rt3572 cinaed 0 2,633 02-15-2018, 03:04 PM
Last Post: cinaed
  Compiling and installing Wifi driver Lexstar 20 34,858 02-15-2018, 04:48 AM
Last Post: cooker
