Looking for donor board to replace voltage regulator or any other ideas?
Lightbulb
My Rock64 have a faulty voltage regulator.  The breakdown happened from a faulty power supply adapter.  It can still boot up a Linux OS but there are a few complications.. HDMI is not working and Its very slow to execute programs.  The error messages are about voltage regulator not responding to the I2C messages so I figured replacing the RK805 voltage regulator might fix it.
The problem is that I don't have a spare RK805 and Pine64 does not want to sell me one, it's understandable but a bummer since there are is nobody else with these chips.  That is why I am asking here for advice.
(04-12-2018, 10:57 AM)ansic Wrote: My Rock64 have a faulty voltage regulator.  The breakdown happened from a faulty power supply adapter.  It can still boot up a Linux OS but there are a few complications.. HDMI is not working and Its very slow to execute programs.  The error messages are about voltage regulator not responding to the I2C messages so I figured replacing the RK805 voltage regulator might fix it.
Unless you have proper de-soldering tool, the success rate of replacing RK805 by hand is low.
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,090 04-26-2023, 11:38 PM
  Audio Pot Board Questions vfr400racer 4 9,685 10-11-2022, 09:21 PM
Last Post: Roberto2020
  Rock64 4K60P HDR Media Board Computer 64 bit MarkHaysHarris777 8 26,853 07-14-2021, 11:52 PM
Last Post: jontumontu
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,684 11-11-2020, 12:48 PM
Last Post: cosmodeal
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 4,057 08-21-2020, 09:16 PM
Last Post: prog-amateur
  Rock64 stereo audio dac add-on board with RockPro64 Tim13 1 5,777 07-08-2019, 07:15 PM
  Rock64 Stereo Audio DAC add-on board Hukmut 3 9,124 06-15-2019, 07:56 AM
Last Post: MiiCode2
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 10,472 01-09-2019, 01:02 AM
Last Post: t4_4t
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 6,667 12-01-2018, 03:53 AM
Last Post: jovval
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD angelscream09 7 14,333 11-21-2018, 07:02 PM
Last Post: antonv
