Shutdown server and corrupt data : how to login ?
Hello !
I have some problems with corrupt data on my Ayufan's Stretch server.
Last night, the external USB 3 HDD suddenly began to vibrate on the desk in the living room. So strongly that it woke us up... I never heard that !
So in the confusion, i just shut down the server holding the power button. And now, impossible to boot the server.
I have some errors before the prompt login :
mmcblk1p6 : Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Give root password for maintenace or press Control D to continue.
I guess there is no password for root login. And Control+D just returns "sulogin cannot read /dev/tty1: Operation not permitted".
And there is no longer ssh connexion.
How can I login as rock64 user and/or run fsck ?
your best bet is if you have access to another linux machine to hook it into that machine and run fsck on the disk. you might be able to get a live Gparted cd to check if partition is corrupted. if no other system, use another image from sdcard boot and look at hd from that.
Thank you. I succeed to repair the hdd with fsck from live Gparted.
I guess it is dead, i can see data but i can't copy my saves :/
  Headless installation of Real VNC server on Rock64 possible? hg6806 3 5,274 11-18-2019, 04:32 AM
Last Post: evilbunny
  Repair corrupt root filesystem on emmc David82 1 3,754 01-31-2019, 01:11 PM
Last Post: Tozzi
  auto login KC7NOA 0 1,904 01-25-2019, 09:50 AM
Last Post: KC7NOA
  Twonky Server PabloFiasko 0 1,694 07-23-2018, 12:25 PM
Last Post: PabloFiasko
  docker contaainer error on "docker login" edwinbmiller 0 1,589 06-18-2018, 10:08 AM
Last Post: edwinbmiller
  VNC server (x11vnc) Skazochnik 1 3,324 02-11-2018, 01:54 PM
Last Post: S3phi40T
  No USB Power after Login (ROCK64+Mate) metaflux 33 40,960 12-17-2017, 10:09 AM
Last Post: joseccz
  PuTTY Disconnected : no supported authentification methods available (server sent : p tomtomtom 3 4,183 11-26-2017, 03:53 PM
Last Post: Luke
  Which one do you think is the best image for running a server for website? fbms 4 5,264 08-28-2017, 07:19 PM
Last Post: fire219
