VNC server (x11vnc)
Hello.
I have some issue with setup remote connection to VNC bu using x11vnc. The main idea is provide remote connection to logon window .
What i did:
Make changes in:
nano /etc/X11/xorg.conf.d/20-modesetting.conf
Section "Monitor"
       Identifier      "Configured Monitor"
EndSection
Section "Screen"
       Identifier      "Default Screen"
       Monitor         "Configured Monitor"
       Device          "Rockchip Graphics"
       SubSection "Display"
               Virtual 1920 1200
       EndSubSection
EndSection
Section "Device"
   Identifier  "Rockchip Graphics"
   Driver      "modesetting"
   Option      "AccelMethod"    "glamor"
   Option      "Dri2Vsync"      "false"
EndSection
Just setup resolution 1920x1200
install x11vnc and password:
sudo apt install x11vnc
$ x11vnc -storepasswd "password" /etc/x11vnc.pass
creating service:
 vi /lib/systemd/system/x11vnc.service
[Unit]
Description=Start x11vnc at startup.
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/bin/x11vnc -auth guess  -forever -loop -noxdamage -repeat -rfbauth /etc/x11vnc.pass -rfbport 5900 -shared
[Install]
WantedBy=multi-user.target
reload services list:
sudo systemctl daemon-reload
enable autostart:
sudo systemctl enable x11vnc.service
start service:
sudo systemctl start x11vnc.service
check status:
sudo systemctl status x11vnc.service
but afre connection i getting black screen with mouse but on monitor i can run application and etc.
Question: Whan have to be changed to get picture on VNC client ?
https://forum.pine64.org/showthread.php?tid=5671
I don't like VNC, but maybe helpful.
Wysłane z mojego Redmi Note 4 przy użyciu Tapatalka
  Headless installation of Real VNC server on Rock64 possible? hg6806 3 5,260 11-18-2019, 04:32 AM
Last Post: evilbunny
  Twonky Server PabloFiasko 0 1,691 07-23-2018, 12:25 PM
Last Post: PabloFiasko
  Shutdown server and corrupt data : how to login ? Florent 2 3,809 02-19-2018, 03:27 PM
Last Post: Florent
  PuTTY Disconnected : no supported authentification methods available (server sent : p tomtomtom 3 4,181 11-26-2017, 03:53 PM
Last Post: Luke
  Which one do you think is the best image for running a server for website? fbms 4 5,262 08-28-2017, 07:19 PM
Last Post: fire219
