Available GPIOs on coming RockPro64
I've noticed that PINE64 plan to provide in a couple of month a board based on the rock chip RK3399. Could you post the pins assignment of the 40 pins connector? I'm particularly interested by I2S0 interface signals (ideally I2S0-SDI0, I2S0-SDO0..3, and clocks), I2C and/or SPI.
Thx
(02-14-2018, 01:31 PM)philw38 Wrote: Hello,
Thx
We will release the 40 pins GPIO map on end of this month after second rev PCB released. In general, for i2s, i2c, spi, and uart, we try to follow back RPi 40pin definition position.
Thx
Thank you for your answer,
However the RPi does not provide a standard pinning which includes I2S. The "standard" audio is managed as an "on board" PWM stream if I understand correctly. Some manufacturers provide audio card etensions. Wolfson (Cirrus Logic) provides a board with 1 stereo input stream and 1 output stereo stream. The HifiBerry has only 1 output stereo stream. My needs are 1 I2S input and at least 1 I2S output, but ideally I would like 4 I2S output (which is what you can get with the I2S #0 RK3399 interface).
Hope you can take into account these needs.
Thx
Thx
Thx
The RK3399 looks like a lot of pins but able assign for GPIO pins are not many. RK3399 don't have internal audio dac and the i2S0 has been assigned fro on board audio codec. I will take your request into account but not promise able to accommodate.
Thx
Thx
Thank you for your answer.
What's doable is to use I2S #1 interface for onboard audio codec (I2S #1 has "only" 1 IN and 1 OUT), and to allow access to the more featured I2S #0 thru the GPIO connectors. This is what Firefly is doing with their RK3399 boards.
Thx
Thx
Thx
Thx
I2S #1 pins have multiplex with other functions. There is another concern is the 1v8 vs 3v0 IO voltage tolerance.
Thx
Thx
Thx
We will expose all four I2S0 data 0-3 pins with clock pins on Rockpro64's Pi2 bus.
(02-14-2018, 05:11 PM)tllim Wrote: We will release the 40 pins GPIO map on end of this month after second rev PCB released. In general, for i2s, i2c, spi, and uart, we try to follow back RPi 40pin definition position.
Thx
Thx
Just to be clear. Here are the GPIOs for I2S0:
  • Y7   : GPIO3_D3/I2S0_SDI0
  • AA6 : GPIO3_D5/I2S0_SDI2SDO2
  • AG3 : GPIO3_D0/I2S0_SCLK
  • AH1 : GPIO3_D7/I2S0_SDO0
  • AE5 : GPIO3_D4/I2S0_SDI1SDO3
  • AF4 : GPIO3_D1/I2S0_LRCK_RX
  • AH2 : GPIO3_D6/I2S0_SDI3SDO1
  • AJ2  : GPIO3_D2/I2S0_LRCK_TX
Do you mean you will expose those 8 signals? If yes that would be perfect  Smile
Thx
(02-15-2018, 02:21 AM)philw38 Wrote: Thank you for your answer,
Thx
Thx
Thx
Correct.
(02-15-2018, 07:30 PM)tllim Wrote: The RK3399 looks like a lot of pins but able assign for GPIO pins are not many. RK3399 don't have internal audio dac and the i2S0 has been assigned fro on board audio codec. I will take your request into account but not promise able to accommodate.
Thx
Thx
Correct.
Good news, thank you.
  Powering two disks from RockPro64 some_pinephone_user 3 4,527 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,296 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 12,599 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 3,815 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 46,023 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 3,539 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 5,919 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 15,652 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 4,165 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 13,937 07-18-2022, 10:05 PM
Last Post: zer0sig
