Interfacing display
Hi folks, just doing some hunting around for information...
I note that the GPIO on the Rock64 is supposed to be capable of emulating Pi2.
I also note that some of the pins are not mapped the same way.
I was using a Pi2 with a Parallel RGB (DPI Mode 2) display. This makes use of pins 11, 29, and 31 which are all "NC" pins on the Rock64.
I am therefore assuming the Rock64 is incapable of interfacing with a RGB 16Bit 565 type display ?
Cheers
Ben
(12-31-2017, 03:26 AM)bencrosby Wrote: I am therefore assuming the Rock64 is incapable of interfacing with a RGB 16Bit 565 type display ?
Correct. There is no RGB or LVDS oder something else to interface a display, just HDMI and CVBS.
  Display options for the Rock64 joey49 1 3,798 11-23-2020, 09:52 AM
Last Post: joey49
  Will Gert's VGA666 adapter work with the Rock64? Other display options? pcosm 0 1,728 05-03-2019, 01:32 AM
Last Post: pcosm
  HDMI display + resistive touch layer. Stratos 4 5,407 10-12-2018, 03:29 PM
  connect lvds display to rock64? heocb 1 3,571 08-16-2018, 01:49 PM
Last Post: mcerveny
  21:9 display (lg ultrawide) fczuardi 3 4,640 06-20-2018, 04:21 PM
Last Post: gaggleoxfoggy
