stretch-minimal with static IP and GUI RDC
Question
I prefer to operate my rock64 via putty in order to use absolute minimal CPU and RAM, as I am going to run intensive dB I/O (R/W) on an external SSD via the USB3 port.
So I downloaded this and installed it:
https://github.com/ayufan-rock64/linux-b...m64.img.xz
Due to not knowing the rock64 setup in detail, I did not manage to setup a static IP addr. so I erased and installed this:
..in order to do the static IP setup via Edit connections on the IP4 tab - and then it worked.
I did try to install - on the stretch-minimal - mate-core mate-desktop-environment and xrdp and edited the startwm.sh with mate-session, then rebooted and tried windows RDC to connect - but that didn't succeed.
I then tried to connect a keyboard, mouse and monitor to the board but was not able to get a desktop with startx.
Am I wrong in thinking that the stretch-minimal version is "better" - and has a smaller CPU/RAM footprint than xenial-mate (full GUI) - even if I install a core version desktop to the stretch version?
Does this question make sense?  Undecided
If true - how do I make stretch work with static IP and accessing it via windows RDC?
Not sure if it's 'better' in whatever way to the xenial image but I love my debian setup now, it's 'Rock'-solid Smile.
Static IP can be configured in /etc/network/interfaces, remove what's there and replace it w smth like:
auto eth0
iface eth0 inet static
address 192.0.2.7
netmask 255.255.255.0
gateway 192.0.2.254
  pcsx rearmed on rock64 debian stretch does not go fullscreen RockyBoulder 2 4,238 05-09-2020, 03:15 AM
Last Post: lawrencejd
  Upgrading Debian Stretch image to Buster cosuhi 2 4,735 08-27-2019, 02:42 AM
Last Post: Malmgren
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 2,273 03-26-2019, 07:28 PM
Last Post: Poincare
  How to get a minimal Debian system started? musbur 3 4,188 02-07-2019, 11:50 AM
Last Post: musbur
  Arch Linux minimal image w/ full HDMI output support hiccupstix 1 3,653 11-01-2018, 08:33 AM
Last Post: danboid
  Watchdog issue on ayufan 0.6.41 build for stretch/armhf/omv4 jata 2 3,850 05-26-2018, 11:09 PM
Last Post: jata
Question Installing the latest kernel (Debian Stretch) + configuring the bootloader? lightknight.rr@gmail.com 3 5,240 05-21-2018, 03:31 AM
Last Post: viguzzz
  Debian Stretch and Kodi Krypton on Rock64 zarusz 28 34,870 05-17-2018, 02:03 PM
Last Post: KernelPanic
  compiling meteor on xenial-minimal-rock64-0.5.15-136-armhf.img.xz maudy 0 1,905 05-02-2018, 05:35 PM
Last Post: maudy
  bringing up X on minimal stretch install gene83 11 12,019 03-05-2018, 01:47 AM
Last Post: jegb
