Does “0.2.14: jenkins-android-7.1-rock-64-69” support wifi?
I flashed "0.2.14: jenkins-android-7.1-rock-64-69" into a sd card, but I could make wifi work.
Anybody know about this?""
(08-22-2017, 07:51 PM)fbms Wrote: I flashed "0.2.14: jenkins-android-7.1-rock-64-69" into a sd card, but I could make wifi work.
no new drivers - just fixes and a raw image. I asked ayufan about wifi/bt drivers and he said it will be a while.
fair enough.
(08-23-2017, 01:15 PM)fbms Wrote: fair enough.
Newest pre-release has realtek drivers
Will those drivers support the wifi card that they sell in the store, because mine still does not work.
I actually found one that works out of the box with an Android EMMC Flash and Sd install.
Just plug it in and it works.
https://www.amazon.com/gp/product/B008IF...=UTF8&th=1
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,277 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,034 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,560 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,623 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,026 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,507 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,023 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,581 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,734 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,819 09-09-2020, 08:44 AM
Last Post: BowerR64
