07-23-2017, 10:07 AM
(07-22-2017, 06:30 PM)Luke Wrote: After some mindless trial and error I got Retroarch working
How did you download a core?
First images with DRM and Mali support for A64
(07-22-2017, 06:30 PM)Luke Wrote: After some mindless trial and error I got Retroarch working How did you download a core?
07-23-2017, 01:25 PM
(07-23-2017, 10:07 AM)Wizzard Wrote:(07-22-2017, 06:30 PM)Luke Wrote: After some mindless trial and error I got Retroarch working This will install all cores. Alternatively specify core instead of * Code: sudo apt-get install libretro*
07-24-2017, 01:23 AM
(07-23-2017, 01:25 PM)Luke Wrote:(07-23-2017, 10:07 AM)Wizzard Wrote:(07-22-2017, 06:30 PM)Luke Wrote: After some mindless trial and error I got Retroarch working Thanks, it works. Sonic the Hedgehog running, just not so smooth like on real Sega Genesis or my PC I also wonder why even Atari 2600 games do not run smooth in full screen mode.
07-24-2017, 06:51 AM
(07-24-2017, 01:23 AM)Wizzard Wrote:(07-23-2017, 01:25 PM)Luke Wrote:(07-23-2017, 10:07 AM)Wizzard Wrote:(07-22-2017, 06:30 PM)Luke Wrote: After some mindless trial and error I got Retroarch working It takes a lot of tweaking to make everything run smoothly. If you have a Pine64 board then just try this - I did all the hard work for you. Its a heavily modified ubuntu image that launches an optimised Retroarch build on boot (note that exiting Retroarch powers down the board).
07-24-2017, 07:00 AM
(07-24-2017, 06:51 AM)Luke Wrote: It takes a lot of tweaking to make everything run smoothly. If you have a Pine64 board then just try this - I did all the hard work for you. Its a heavily modified ubuntu image that launches an optimised Retroarch build on boot (note that exiting Retroarch powers down the board). I have Pinebook only, so I think I will not use this, but thanks anyway.
07-25-2017, 01:22 AM
I wonder why is 2D graphics so slow when DRM is enabled and fast while it is disabled. I see the difference mainly when moving the windows etc. in KDE Plasma.
07-25-2017, 04:07 AM
(07-25-2017, 01:22 AM)Wizzard Wrote: I wonder why is 2D graphics so slow when DRM is enabled and fast while it is disabled. I see the difference mainly when moving the windows etc. in KDE Plasma. Yeah, I noticed that too... DRM sucks when just doing normal desktop-y stuff (there you go tkaiser... that's the benchmarking for you... it sucks :-P - and it will have to remain empirical benchmarking for now as the tools I've tried so far don't wanna work on the pinebook) ... but now that there is a proper enable/disable script (thanks ayufan!) I'm leaving it disabled and re-enabling my nice software composition effects ... too many white flashing boxes and other artefacts just doing things like dragging a window or opening a caja window for me to warrant leaving it on for everyday use. But that's fine for me atm... I don't do anything that warrants needing DRM AND 'normal' 2D performance atm, so I can live with that.
07-25-2017, 06:47 AM
Can you check how it works with fbturbo?
I would expect the performance to be roughly the same, as it doesn't really differ.
Homepage: https://ayufan.eu
Releases: Rock/Pro 64/Pinebook Pro: Linux; Chromium OS So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1 Buy me a Beer
07-25-2017, 06:57 AM
What is fbturbo?
07-26-2017, 05:57 AM
Wizzard, since you were keen on trying retroarch on the Pinebook please run this script on a ubuntu minimal image
Official Debian support! | Luke | 85 | 133,356 |
05-13-2024, 12:28 PM Last Post: foresto |
official support for aarch64 in OpenArena | Opvolger | 0 | 1,599 |
03-24-2022, 02:23 PM Last Post: Opvolger |
Fedora 32 Release, improved support for Rock(Pro)64 | Tharadash | 2 | 5,962 |
05-05-2020, 08:37 AM Last Post: zer0sig |
Kickstarter: Allwinner VPU support in the official Linux kernel | xalius | 8 | 15,080 |
10-03-2019, 03:03 AM Last Post: bunkerWHz |
