Error formatting MicroSD
#21
Phoenixcard, like other android imaging software, is mainly designed to flash on-board nand or emmc, which you can't just pop into a usb reader and point dd or windiskimager at. SD card programming was an afterthought. Don't blame pine for this load of excrement -- it's from allwinner. Unfortunately, (some/many/most) hardware companies suck at software design, and very few design manufacturing tools for linux. Even Freescale's (now something like NXP) flash programming tool is windows only.
#22
(04-06-2016, 05:34 AM)Rhymoore Wrote: Hi,
I had kinda the same problem, when i tried to install / burn an image via phoenix.
I plainly used the micrsoft formatting software (my computer, right click the sd card format (fat32, standard)) and then i was able to burn an image (need to start the phoenix software with admin (right click the exe launch as administrator). It only took the software about 1 minute.
i am using windows 10.
Thanks for this suggestion Rhymoore, it worked perfectly for me! I tried so many things before this and only your workaround was the solution. Its so simple too. Hope others can find this little tip.
  SD card too small Error loungehound 7 12,672 01-21-2017, 05:37 PM
Last Post: Bluphire
  Netflix (v4.9.5) Error 1018 on Playback evanthor 3 15,995 12-19-2016, 09:24 AM
Last Post: Bluphire
  MicroSD Size mismatch with Image Hbtr 23 28,509 08-31-2016, 09:00 AM
Last Post: montero65
  Change MicroSD card AA666 2 4,483 05-26-2016, 01:20 PM
Last Post: AA666
