Q4OS for PINEBOOK
#41
(07-20-2017, 04:19 AM)q4osteam Wrote: Select "Copy here"
- Now I am able to rename the desktop icon using "right mouse click > rename" or "F2" key
Please specify some more details for us to be able to reproduce and fix the issue you have described.
Hmmm - I did use "Link here" for a Shortcut.
When I do rename the Icon and press Enter - it got its original name in the first try
When doing a second try to rename then the icon has changed at the desktop.
Sometimes - after a reboot - the icon has again its old name Sad
I want to rename "Chromium Webbrowser" and "VLC Mediaplayer" to "Chromium" and "VLC"
or "MATE-Terminal" to "Terminal" only.
Got this with my Pinebook and on my x86-laptop....
#42
(07-20-2017, 06:13 AM)guidol Wrote: When I do rename the Icon and press Enter - it got its original name in the first try
Thanks, I can confirm such confusing bearing, if you create a "Link" to root owned shortcut on the desktop. It will be included as a bug in our internal bug list and treated as soon as possible.
(07-20-2017, 06:13 AM)guidol Wrote: I want to rename "Chromium Webbrowser" and "VLC Mediaplayer" to "Chromium" and "VLC"
You just need to use "Copy" command, as it will create a user owned and editable copy of that shortcut.
#43
Ahh :Smile did use too much Windows - when used copy from the Explorer I will get a copy of the .EXE
Now here on Q4OS its a root-owned Link already so copy will only do a User-Copy of the Link - I see Smile
Thanks for the information Smile
#44
Is Q4OS faster than ubuntu 16.04 mate on pinebook? Smile
#45
I did this:
sudo dd bs=4M if=image.iso of=/dev/mmcblk1
On my pinebook (Ubuntu 16.4) for Q4OS image and it is not booting when I restart. I need to press something to start booting from sd card?
#46
(08-13-2017, 04:28 PM)shirman Wrote: I did this:
nope. It should start from SD after a restart - SD has boot priority. Perhaps you didnt flash the image correctly ?
#47
How can I check result of flashing?
#48
(08-13-2017, 04:55 PM)shirman Wrote: How can I check result of flashing?
Pineinstaller does that for you. DD and the Disks GUI utility that comes with ubuntu-based distros does not.
Did you select 'Pinebook' from the drop-down menu? Pine64 or SoPine images wont work.... perhaps you are booting an image for the wrong device ?
#49
I can't use Pineinstaller because I have not any sd card reader, for now, so I can burn SD image only on my Pinebook via DD or gnome-disk, Pineinstaller is not working on ARM at the moment Sad
#50
Disks worked well for me on the PB.
  DietPi OS for Pinebook MichaIng 3 5,367 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,864 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 891 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 685 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,572 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,218 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,844 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,241 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,806 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,794 12-25-2020, 04:40 PM
Last Post: ford442
