Error formatting Memory Card
Another method to start fresh with a Micro SD or usb drive if you are on windows is the following:
1. Start> Run> diskpart
2. in the command prompt type 'list disk' (without the quotes), and identify the disk number.
3. type 'select disk #' (# = the disk number identified in previous step.)
4. type 'clean'
5. once that is compete, type 'create partition primary'.
6. close diskpart, go to explorer and double click your removable device, it will ask you to format it. Format to FAT32 or NTFS.
7. Proceed with using either Win32DiskImager or Phoenix to write your image to disk.
I hope this helps anyone else who had a few issues like i did after a few image burns gone bad. This resolved a lot of issues for me Smile.
  PBP Debian 11 GRUB install error zlth 2 1,952 11-18-2022, 07:42 AM
Last Post: zlth
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 1,615 05-23-2022, 08:49 AM
Last Post: 98cwitr
  How to boot from SD card on pinebook pro linux123 3 6,094 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,478 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,384 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,472 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 213,380 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 11,262 03-20-2018, 11:14 AM
Last Post: Malmgren
  Upgrading Memory on PINE64 + 2GB Osh818 2 5,107 04-24-2017, 10:12 PM
Last Post: Osh818
  corrupt microsd card after reboot maxpayne 6 10,116 02-08-2017, 05:42 PM
Last Post: maxpayne
