02-17-2016, 01:20 PM
I have ordered the 7" LCD with my board which lists a 4 Lane MIPI DSI Ribbon Port. What cable do I need to connect it to my board?
Thanks,
Thanks,
Cable for LCD
Thanks,
02-17-2016, 01:55 PM
02-17-2016, 01:59 PM
(02-17-2016, 01:55 PM)SkairkrohBule Wrote:(02-17-2016, 01:20 PM)sbentjies Wrote: I have ordered the 7" LCD with my board which lists a 4 Lane MIPI DSI Ribbon Port. What cable do I need to connect it to my board? Yeah that would be shitty for it not to...
02-17-2016, 10:07 PM
02-17-2016, 10:14 PM
(02-17-2016, 10:07 PM)tllim Wrote:(02-17-2016, 01:20 PM)sbentjies Wrote: I have ordered the 7" LCD with my board which lists a 4 Lane MIPI DSI Ribbon Port. What cable do I need to connect it to my board? Which attaches to a port on the board I assume
02-17-2016, 10:26 PM
(02-17-2016, 10:14 PM)sbentjies Wrote:Yes. attached to both LCD and TP ports.(02-17-2016, 10:07 PM)tllim Wrote:(02-17-2016, 01:20 PM)sbentjies Wrote: I have ordered the 7" LCD with my board which lists a 4 Lane MIPI DSI Ribbon Port. What cable do I need to connect it to my board?
02-18-2016, 06:30 AM
(02-17-2016, 10:26 PM)tllim Wrote:(02-17-2016, 10:14 PM)sbentjies Wrote:Yes. attached to both LCD and TP ports.(02-17-2016, 10:07 PM)tllim Wrote:(02-17-2016, 01:20 PM)sbentjies Wrote: I have ordered the 7" LCD with my board which lists a 4 Lane MIPI DSI Ribbon Port. What cable do I need to connect it to my board? TP? (02-18-2016, 06:30 AM)sbentjies Wrote:(02-17-2016, 10:26 PM)tllim Wrote:(02-17-2016, 10:14 PM)sbentjies Wrote:Yes. attached to both LCD and TP ports.(02-17-2016, 10:07 PM)tllim Wrote:(02-17-2016, 01:20 PM)sbentjies Wrote: I have ordered the 7" LCD with my board which lists a 4 Lane MIPI DSI Ribbon Port. What cable do I need to connect it to my board? Touch panel.
02-28-2016, 12:59 PM
Hello, I noticed that Pine A64 uses MIPI DSI and touch port. I know the MIPI DSI is 4 pin but what kind is the touch controller port? Will this work? It says it has S3402 touch ic controller. I have also seen some with S3508 touch ic.
02-28-2016, 01:47 PM
(02-28-2016, 12:59 PM)matthewclso Wrote: Hello, I noticed that Pine A64 uses MIPI DSI and touch port. I know the MIPI DSI is 4 pin but what kind is the touch controller port? Will this work? It says it has S3402 touch ic controller. I have also seen some with S3508 touch ic. You can't assume that touch panel controllers are interchangeable. If you can't find out more about that touch IC and find an existing linux driver for it, you won't get it to work out of the box without writing or adapting a different driver to it. |
Ribbon Cable Extenders ? | Severian | 14 | 23,413 |
08-04-2016, 02:11 PM Last Post: jodybrown99 |
