Add on Module on Survey
Hi
I had pledged the campaign ($29) plus 7 dollars shipping fee.
I got a survey email and go to the website.. I saw there is option (PINE64 Boards) which we can add Pine64 board.
My question is whether I need to choose/add the board, or not since I have a pledge (2gb board) already...
Again I just only need one board for now....
Is the survey only for add-on module only? So we do not need to add the board! The board will be come with the addition modules which I add...
Thanks.
-C
(02-17-2016, 12:23 PM)cowell33 Wrote: Hi
Thanks.
-C
In the Backerkit survey, you can upgrade an existing board, and/or add on extra boards. You do not need to add the board you already pledged for through the kickstarter, no. That is already confirmed.
I think that you need to complete the survey to verify your shipping and billing information. The other reason that you should review it is that you might want add-ons or upgrades. For example, you might want to add a case or the WiFi/bluetooth card and you would need to select those and pay extra for them if desired.
As you point out, this is also an opportunity to add existing boards (or upgrade current board orders).
If you do not want any add-ons or additional boards, you will still need to complete the survey so that the Pine folks get your shipping information. The survey will reflect your KS backing and you will get that amount credited to your order. Hence, if you don't want anything but one board and you pledged for it (and shipping) then you will not have to pay anything at the end of the process.
  USB adapter to eMMC module not recognized danril 0 1,325 11-25-2022, 04:16 AM
Last Post: danril
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,580 10-06-2022, 08:46 PM
Last Post: ihab
  Getting z-wave module working under ubuntu marcosti 6 11,996 02-10-2017, 07:53 AM
Last Post: JamesWatt
  Is the Wifi module working? clawinus 8 10,691 11-23-2016, 10:09 AM
Last Post: clawinus
  how to install Wifi/Bluetooth module danlcarr 2 4,268 10-08-2016, 09:59 PM
Last Post: danlcarr
  WiFi module causes boot loop BnEc 17 25,543 09-24-2016, 09:12 PM
Last Post: pfeerick
  LCD works only when Wifi Module not installed nesalot 2 4,561 09-03-2016, 03:53 AM
Last Post: nesalot
  Wifi 802.11BGN/ Bluetooth 4.0 Module jesse1234 1 3,154 07-26-2016, 11:26 AM
Last Post: MarkHaysHarris777
  WiFi/BT module not working on Android lesilva 7 10,486 05-02-2016, 07:51 AM
Last Post: lesilva
