External Hard Drives
hello and happy new years every one.
I have a 1to external USB hard drives  and ubuntu OS on SD card
I would like to know If I can plug it to the USB port with 2A power supply. it will be start well or not or I must to change power supply?
thank you.
(01-04-2017, 10:21 AM)hazerty Wrote: hello and happy new years every one.
thank you.
You will need to use a powered hub;  or else provide external power to the drive ( there are many ways to do this ).
This is discussed in length on:
http://forum.pine64.org/showthread.php?tid=783
Just a FYI
I bought a 7 USB 3.0 hub with external power and it works fine now. The hub is running on 5V 500mA
Sent from my SM-G935F using Tapatalk
Question External storage problem for pine64 Dani6102 4 1,756 08-22-2023, 08:36 AM
Last Post: gulshan212
  usb 3.0 external hard drive not recognized. eclay 2 4,708 11-23-2018, 10:30 AM
Last Post: eclay
  Some hard numbers on Pine64 Power Usage ataylorm 2 8,014 06-27-2016, 06:08 AM
Last Post: ataylorm
