Running UniFi Controller on a Pine A64+ 1Gb board
Hi all!
Pine64 is a very cost effective solution for running the UniFi Controller. The installation process is a bit tricky though. Hence sharing my experience: https://ishwestscriptwault.wordpress.com...pine64-en/
Enjoy!
(12-29-2016, 03:03 AM)ishwest Wrote: Hi all!
Enjoy!
hanks on sharing your experience.
Did you get the new 5.5.19 version running.
I'm stuck in the upgrade with constant error in the log wrt tomcat
(07-05-2017, 06:42 AM)mrv Wrote: Did you get the new 5.5.19 version running.
No, not yet. I'll try upgrading controller some time next week. Will post in this thread.
I confirm the problem.
Controller fails before (or while?) converting the db from 5.4 to 5.5.
So a clean install might work.
I'll look into it further.
In the mean time I succeeded.
However was a big pain..
The upgrade always fails, the way I managed was to install the unifi controller Windows version, than use that to upgrade. Than transfer the upgraded file to a clean version on the pine
(07-13-2017, 10:06 PM)mrv Wrote: … install the unifi controller Windows version, than use that to upgrade. Than transfer the upgraded file to a clean version on the pine
Thanks for the update!
This imho suggests that the migration process relies either on a native library or an external program that is missing.
Or it might be just a bug in the new controller version :-)
I was able to upgrade with a fresh install of 5.5.19.  The trick for me was to install the latest stable mongodb before attempting to upgrade.  The directions for installing mongodb on ubuntu are at https://docs.mongodb.com/manual/tutorial...-on-ubuntu.
  Pine 64 installer OS list blank spamsucks 1 1,071 04-08-2025, 08:16 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 3,300 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 1,343 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 6,266 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 7,879 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 4,420 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 5,567 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 9,795 12-06-2020, 03:53 PM
Last Post: junkyj753
  How to build Webradio from Board A64 ? Bebert 5 9,317 08-19-2020, 12:49 PM
Last Post: Bebert
Lightbulb Xbox 360 controller NOT recognized lawrencejd 0 3,043 04-09-2020, 03:47 PM
Last Post: lawrencejd
