Remote Access Server [Suggestions?]
Brick
I'm planning on running a server from my Pine64, and after i set everything up, i want to put the Pine in a closet or something. I was hoping i could use something to access the Pine from a different computer or device, so i did some research.
I found this: https://www.realvnc.com
If you look at their downloads page, found here, it lists a bunch of versions of their software for a bunch of operating systems. They have viewers for a bunch of operating systems as well.
Do you think this VNC software will work on the Pine64? If so, which operating system would you recommend? (I was hoping for some flavor of Linux to save resources, but anything is up for suggestion. I was thinking that a graphical remote connection would be easier than just command-line.)
Opinions?
If I've helped you with something, please leave a rating for my responses.
You can install a VNC server on the Pine64 (in Linux, in development), and then configure to access it remotely.
Such an installation does not even require to install drivers for the graphics card of the Pine64.
In Debian/Ubuntu there is a package called tightvncserver (http://www.tightvnc.com/)
which is one of the most common for this task.
I would say it largely depends on what the purpose for having a remote connection to your device.
I use RealVNC for my Ubuntu server for general purpose stuff that I like to have the GUI for (uploading files to a work DropBox and such) but default to SSH whenever I know what I'm doing can be done via command line.
  PINE as Wireless Repeater/Access Point? Dizzy49 7 19,094 04-01-2020, 09:38 AM
Last Post: ssgulliver
  Mastodon instance \ Nextcloud Server fearg 1 7,712 03-31-2020, 08:18 PM
  Plex server arghne 59 192,943 07-06-2018, 10:36 AM
Last Post: Moshe.Vazan
  Turn your Pine64 into a music server with mpd JulianM 2 14,980 03-23-2017, 10:50 PM
  Plex server arghne 48 82,391 03-22-2017, 04:15 AM
Last Post: pineadmin
  Pine64 as NAS/Media Server VandaL.pr! 1 8,557 12-27-2016, 10:48 AM
Last Post: Luke
  3d printer server oldsmarracin 3 8,769 09-13-2016, 02:43 AM
Last Post: JAYJAYN
  Cannot install Plex Media Server under Arch Linux malevolent 2 8,688 09-11-2016, 12:20 PM
Last Post: ChrisLane
  Building Stratum One NTP Server lospinos 5 14,208 08-23-2016, 09:23 AM
Last Post: MarkHaysHarris777
  Starbound Server. Is the Pine64 capable? iamfallen 1 6,079 08-03-2016, 10:36 AM
