05-09-2016, 02:17 PM
I think I got the same error and even with that error is working (In my case).
Proposal Status Link to Forum=> PINE64 Status Forum
Remenber to Upvote Proposed questions. And give a Follow.
Plex server
![]() Proposal Status Link to Forum=> PINE64 Status Forum Remenber to Upvote Proposed questions. And give a Follow.
I was able to install Plex without a problem by following what tkaiser said to do step by step. If you are not going to follow the directions I really do not find it fair to ask him for help. The image he points to for Debian works great. I installed it and actually did some stress testing and found I could stream 5 1080P videos to 5 different devices. 2 of them were trans coding. (Audio only)
Thanks tkaiser
05-09-2016, 05:24 PM
(This post was last modified: 05-09-2016, 05:30 PM by malevolent.)
This one then?
http://forum.pine64.org/showthread.php?tid=376 I'm gonna try it, but network it's damn slow with that... EDIT: No, that image doesn't work either... please, could anyone paste a link with the working image? I've tried a bunch of them, but I'm out of luck...
05-10-2016, 10:59 AM
(05-09-2016, 05:24 PM)malevolent Wrote: This one then? https://www.stdin.xyz/downloads/people/l...es/ubuntu/ That is the one I used. It worked great if you want to do a headless Plex Server
05-10-2016, 12:09 PM
I tried xenial-pine64-bspkernel-20160507-1.img.xz yesterday, it failed, I'm going to try xenial-pine64-bspkernel-20160424-1.img.xz right now...
05-10-2016, 12:23 PM
All my images work - it does not matter which one you try.
05-10-2016, 01:16 PM
(This post was last modified: 05-10-2016, 01:23 PM by malevolent.)
Pals... I don't know, really...
![]() I put the logs, if you could take a look on actions, perhaps you can see what I'm doing wrong... http://pastebin.com/nE8sMFDy Thank you... (05-10-2016, 12:23 PM)rahlquist Wrote:(05-10-2016, 12:09 PM)malevolent Wrote: I tried xenial-pine64-bspkernel-20160507-1.img.xz yesterday, it failed, I'm going to try xenial-pine64-bspkernel-20160424-1.img.xz right now... Both
05-10-2016, 01:24 PM
What do you need? It cleary states what is wrong in your log "as repository 'https://dev2day.de/pms jessie InRelease' doesn't support architecture 'arm64'" - what else do you need?
05-10-2016, 01:35 PM
(This post was last modified: 05-10-2016, 01:35 PM by malevolent.)
(05-10-2016, 01:24 PM)longsleep Wrote: What do you need? It cleary states what is wrong in your log "as repository 'https://dev2day.de/pms jessie InRelease' doesn't support architecture 'arm64'" - what else do you need? Perhaps I'm not understanding anything, but as fas as I can understand, plex installs on that device with this repo... and if I didn't understand either wrong what others said, they could it make it work on pine64 with those steps. I even saw a screenshot of plex working on it. Am I understanding it bad? |
Mastodon instance \ Nextcloud Server | fearg | 1 | 3,259 |
03-31-2020, 08:18 PM Last Post: tllim |
Turn your Pine64 into a music server with mpd | JulianM | 2 | 9,267 |
03-23-2017, 10:50 PM Last Post: tllim |
Plex server | arghne | 48 | 35,844 |
03-22-2017, 04:15 AM Last Post: pineadmin |
Pine64 as NAS/Media Server | VandaL.pr! | 1 | 4,959 |
12-27-2016, 10:48 AM Last Post: Luke |
3d printer server | oldsmarracin | 3 | 3,973 |
09-13-2016, 02:43 AM Last Post: JAYJAYN |
Cannot install Plex Media Server under Arch Linux | malevolent | 2 | 4,216 |
09-11-2016, 12:20 PM Last Post: ChrisLane |
Building Stratum One NTP Server | lospinos | 5 | 5,932 |
08-23-2016, 09:23 AM Last Post: MarkHaysHarris777 |
Starbound Server. Is the Pine64 capable? | iamfallen | 1 | 2,929 |
08-03-2016, 10:36 AM Last Post: MarkHaysHarris777 |
Minecraft Server | chrislink14 | 16 | 21,637 |
05-06-2016, 08:03 AM Last Post: jeremycobert |
Media server | montero65 | 3 | 4,548 |
04-28-2016, 06:02 PM Last Post: queonda |
