No IMG file after extracting Android dd
Did you by chance download http://files.pine64.org/os/sdk/A64-ver2.....0-SDK.zip ? That is the Android source SDK and not a disk image. AFAIK there are no Marshmallow images released yet...
(08-10-2016, 10:06 AM)xalius Wrote: Did you by chance download http://files.pine64.org/os/sdk/A64-ver2.....0-SDK.zip ? That is the Android source SDK and not a disk image. AFAIK there are no Marshmallow images released yet...
This is the one I downloaded
Android Marshmallow ver 6.0
  • Is it the same for the Lollipop version ?
You'll note the file name specifically says its an SDK.
Android images are here: http://wiki.pine64.org/index.php/Pine_A6...ge_Release
be sure to select the correct one based on your display choice.
(08-10-2016, 02:14 PM)DonFL Wrote: You'll note the file name specifically says its an SDK.
I did not download the SDK, I downloaded the one off the same page you just included. The question was asked if I had downloaded the SDK, and I replied that I had not. It may be possible that they have the SDK hyperlinked rather than the IMG though.
I did not say that you did...I was referring to the link "Obewon" provided, reference posts 10 and 12.
My bad for not quoting his post and making that clear.
Thanks for clarifying, in hindsight, that makes sense. Smile
Question Do I need a touchscreen to run Android? chrbar 3 5,153 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 2,638 04-23-2018, 01:47 AM
Last Post: fulltone
  No sound on Android 6 or 7.1 reeno 0 2,927 07-29-2017, 06:31 PM
Last Post: reeno
  Android pretty slow Passiday 2 5,064 10-08-2016, 03:46 AM
Last Post: Passiday
  Can't make the Android image boot Passiday 3 5,500 10-07-2016, 09:34 AM
Last Post: Passiday
  LCD screen with android, runs fine, screen does not turn back on..? GhostlyAspens 2 4,272 09-01-2016, 12:24 AM
Last Post: GhostlyAspens
  Can't get past the "Allwinner/Android" screen d34532 2 5,114 07-10-2016, 08:21 PM
Last Post: d34532
Thumbs Down Issues with Android mliebski 0 2,014 07-01-2016, 11:14 AM
Last Post: mliebski
  Android Touchscreen/HDMI Severian 2 5,093 06-18-2016, 03:28 PM
Last Post: Severian
  Android: Works on monitor but not on HDTV wickemt 2 4,799 06-13-2016, 09:54 AM
Last Post: wickemt
