Android: Works on monitor but not on HDTV
Howdy. Thanks in advance to everyone who has contributed time and effort to the software for these boards, I'm excited to see where things go from here.
Bought the pine to replace my clunky HTPC, which is going in a closet to become a media server. After much wailing and gnashing of teeth, I got Android running on an old 32GB micro SD card (interestingly, I bought a 64GB Class 10 SD card but it was slow as hell and apps kept crashing. the 32gb "slow" card works fine). Did all my testing and setup plugged into a brand new LG 27" IPS monitor direct to HDMI. Then I went to plug the Pine into my home theater system, Pine -> Receiver/HDMI Switcher -> 5 year old Philips plasma TV.
No signal. Then tried directly to the TV, HDMI-HDMI. No signal.
I know the card is good and the board is good, because I'm able to use Android on the LG monitor. What do I need to do to get it working on the TV? I'm not trying to buy a new TV just to get this board working.
hmm. Could be something to do with the interlaced resolution of the plasma. What is the native resolution ?
(06-09-2016, 07:32 AM)Luke Wrote: hmm. Could be something to do with the interlaced resolution of the plasma. What is the native resolution ?
I'm not sure. It's 1080i or 1080p, because I run my current HTPC through it without a problem at 1920x1080.
If this helps, it doesn't work either routed through my Yamaha HDMI head unit, or direct to the TV.
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,912 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Pine HDMI -> DVI monitor Pineapple 4 7,806 09-10-2019, 11:28 AM
Last Post: Pineapple
Question Do I need a touchscreen to run Android? chrbar 3 5,156 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 2,639 04-23-2018, 01:47 AM
Last Post: fulltone
  No sound on Android 6 or 7.1 reeno 0 2,928 07-29-2017, 06:31 PM
Last Post: reeno
  SSH works, but no video SvdSinner 8 10,833 12-08-2016, 12:59 PM
Last Post: MarkHaysHarris777
  Android pretty slow Passiday 2 5,068 10-08-2016, 03:46 AM
Last Post: Passiday
  Can't make the Android image boot Passiday 3 5,503 10-07-2016, 09:34 AM
Last Post: Passiday
  LCD works only when Wifi Module not installed nesalot 2 4,567 09-03-2016, 03:53 AM
Last Post: nesalot
  LCD screen with android, runs fine, screen does not turn back on..? GhostlyAspens 2 4,274 09-01-2016, 12:24 AM
Last Post: GhostlyAspens
