Max Ethernet Throughput PineA64+
Hello ,
I was investigating the max throughput via Ethernet of the Raspberry Pi3 model B+ since it has supposedly 1000Gbps Ethernet; but since this Ethernet runs over USB 2.0 Bus, it gives supposedly a max throughput of around 300Mbps.
Would like to investigate if this is the same for the Pine A64+ or if this board is more modern in this regard, eg. capable of higher throughputs over Ethernet?
Thank you very much for your answers.
thanks I think the answer is that the pine a64 is actually capable of the 1 Gbps over Ethernet;
tried this with iperf3
and got the results for Pine A64+ (2 GB version)
[ 4] local 192.168.0 port 49776 connected to 192.168.0 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 108 MBytes 910 Mbits/sec
[ 4] 1.00-2.00 sec 113 MBytes 944 Mbits/sec
[ 4] 2.00-3.00 sec 112 MBytes 944 Mbits/sec
[ 4] 3.00-4.00 sec 113 MBytes 944 Mbits/sec
[ 4] 4.00-5.00 sec 112 MBytes 943 Mbits/sec
[ 4] 5.00-6.00 sec 113 MBytes 944 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 943 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 943 Mbits/sec
[ 4] 8.00-9.00 sec 112 MBytes 943 Mbits/sec
[ 4] 9.00-10.00 sec 112 MBytes 943 Mbits/sec
[ 4] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec sender
[ 4] 0.00-10.00 sec 1.09 GBytes 937 Mbits/sec receiver
whereas on the Raspberry Pi2 Model B with a USB 3 Ethernet Dongle (over Usb2.0 port) got the following results
[ 4] local 192.168.0 port 49794 connected to 192.168.10 port 5201
[ 4] 0.00-1.00 sec 39.8 MBytes 333 Mbits/sec
[ 4] 1.00-2.00 sec 36.5 MBytes 306 Mbits/sec
[ 4] 2.00-3.00 sec 36.6 MBytes 307 Mbits/sec
[ 4] 3.00-4.00 sec 37.0 MBytes 310 Mbits/sec
[ 4] 4.00-5.00 sec 36.6 MBytes 307 Mbits/sec
[ 4] 5.00-6.00 sec 36.5 MBytes 307 Mbits/sec
[ 4] 6.00-7.00 sec 36.6 MBytes 307 Mbits/sec
[ 4] 7.00-8.00 sec 37.1 MBytes 312 Mbits/sec
[ 4] 8.00-9.00 sec 36.7 MBytes 308 Mbits/sec
[ 4] 9.00-10.00 sec 36.5 MBytes 307 Mbits/sec
[ 4] 0.00-10.00 sec 370 MBytes 310 Mbits/sec sender
[ 4] 0.00-10.00 sec 366 MBytes 307 Mbits/sec receiver
iperf Done.
hence if the Raspberry Pi3 Model B+ still has the Ethernet going over the Usb 2.0 bus, the results should be similar to those of the Raspberry Pi2 Model B.
(please disregard the IP numbers for the SBCs since changed those for this post).
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,354 02-09-2021, 12:17 AM
  +LTS/SOPINE pinea64 fast enough for software like libreoffice? heocb 0 2,042 08-19-2019, 11:21 AM
Last Post: heocb
  Usb and ethernet ports adamjedgar 2 3,650 02-26-2017, 06:57 PM
Last Post: adamjedgar
  What is the most stable OS for PINEA64 victorssantos 1 2,966 10-19-2016, 01:33 PM
Last Post: clarkss12
