Infinitime Build problem
Hi guys,
I'm trying to build Infinitime project on my windows machine but with no success. I have been following the steps in:
https://github.com/InfiniTimeOrg/InfiniT...Program.md
I'm stuck in the last step, the make command.
Cmake command:
Cmake -DARM_NONE_EABI_TOOLCHAIN_PATH="C:/Program Files (x86)/GNU Arm Embedded Toolchain/10 2021.10" -DNRF5_SDK_PATH="C:/Users/blackdev/pinetime/nRF5_SDK_15.3.0_59ac345" -DCMAKE_BUILD_TYPE=Debug -DBUILD_DFU=1 -DBUILD_RESOURCES=1 -DTARGET_DEVICE=PINETIME -S . -B build
Which results in adding the following files inside build folder
├───CMakeFiles
│   ├───3.28.0-rc2
│   │   ├───CompilerIdASM
│   │   ├───CompilerIdC
│   │   │   ├───Debug
│   │   │   │   └───CompilerIdC.tlog
│   │   │   └───tmp
│   │   ├───CompilerIdCXX
│   │   │   ├───Debug
│   │   │   │   └───CompilerIdCXX.tlog
│   │   │   └───tmp
│   │   └───x64
│   │       └───Debug
│   │           └───VCTargetsPath.tlog
│   ├───58e9d56eaa4cb413b76d7d838cbc8fb1
│   ├───74be971449aa6aebb611e3cfdd9dd126
│   ├───83f795d81ab7de042a55dc014fe330ec
│   ├───CMakeScratch
│   └───pkgRedirects
└───src
    ├───CMakeFiles
    └───displayapp
        └───fonts
            └───CMakeFiles
Then I enter the build folder and I try to use make command as described in the above link
make -j4 pinetime-app
It doesn't work, it says:
"make: *** No rule to make target 'pinetime-app'.  Stop."
I also tried make -j4, but similar issue.
Any hints and guidance would be greatly appreciated.
I guess there's something wrong at cmake:
first enter the build-dir in your src-dir: cd build
then:
Cmake -DARM_NONE_EABI_TOOLCHAIN_PATH="C:/Program Files (x86)/GNU Arm Embedded Toolchain/10 2021.10" -DNRF5_SDK_PATH="C:/Users/blackdev/pinetime/nRF5_SDK_15.3.0_59ac345" -DCMAKE_BUILD_TYPE=Debug -DBUILD_DFU=1 -DBUILD_RESOURCES=1 -DTARGET_DEVICE=PINETIME ../
  Bluetooth BLE-MIDI-controller app for PineTime / InfiniTime Luno 0 2,729 08-20-2023, 05:17 AM
Last Post: Luno
  Datetimecontroller problem when accessing on other cpp file Vishalnaik 0 2,529 02-27-2023, 04:05 AM
Last Post: Vishalnaik
  Can't build InfiniTime Anonymous1 1 4,360 01-25-2023, 01:49 AM
Last Post: matthewfelgate
  error when try to build infinitime 1.10 gy145 2 5,593 07-08-2022, 08:23 PM
Last Post: gy145
  Daemon and go library to interact with InfiniTime on Linux Arsen6331 0 3,174 08-21-2021, 10:32 AM
Last Post: Arsen6331
  Build Infinitime Sources aemkai 4 8,658 08-01-2021, 01:41 PM
Last Post: JF002
Information InfiniTime Default Face USA Mod - No longer supported The3DmaN 1 4,902 02-25-2021, 03:51 PM
Last Post: The3DmaN
  InfiniTime Avamander 4 10,643 02-24-2021, 02:38 PM
Last Post: Avamander
  Build PineTime Firmware in the Cloud lupyuen 3 9,086 07-27-2020, 04:54 PM
Last Post: lupyuen
