InfiniTime
InfiniTime
InfiniTime is a PineTime firmware that is lightweight, tidy, supported by multiple companion apps and in active development. It's the current factory-default firmware on the PineTime.
The goal of this project is to design an open-source firmware for the Pinetime smartwatch:
Overview
  • Fast and optimized LCD driver
  • Bluetooth LE (BLE) communication
  • Rich user interface via display, touchscreen and pushbutton
  • Time synchronization via BLE
  • Notification via BLE
  • Multiple watchapps:
        - Clock (displays the date, time, battery level, BLE connection status)
        - Music control
        - System info (displays various info: BLE MAC, build date/time, uptime, version...)
        - Brightness (allows the user to configure the brightness of the display)
  • Supported by 2 companion apps (development is in progress):
        - Gadgetbridge (on Android)
        - Amazfish (on SailfishOS)
  • [Experimental] OTA (Over-the-air) update via BLE
  • [Experimental] Bootloader based on MCUBoot
Getting started
Build, flash and debug
Contribute
API
Architecture and technical topics
Check the GitHub repository for even more details!
https://github.com/JF002/InfiniTime
Ignore the wonky formatting, the forum's text editor is utterly unusable and super buggy.
InfiniTime just got a new release 0.8.3!
It's a hotfix release that helps avoid a hang that is often caused by a force reset done when the watch is in deep sleep.
InfiniTime just got a new pre-release 0.10.0 that more adventurous people can try out!
It has two new games and a bunch of small fixes.
https://github.com/JF002/InfiniTime/releases/tag/0.10.0
InfiniTime 0.11.0 is out with Heart Rate and Navigation watchapps!
Beta testers can find downloads here: https://github.com/JF002/InfiniTime/releases/tag/0.11.0
InfiniTime 0.14.0 has been released with upgraded UI and a few bugfixes!
Beta testers can find downloads here: https://github.com/JF002/InfiniTime/releases/tag/0.14.0
  Infinitime Build problem BlackDev 1 619 12-23-2023, 08:07 AM
Last Post: Luno
  Bluetooth BLE-MIDI-controller app for PineTime / InfiniTime Luno 0 497 08-20-2023, 05:17 AM
Last Post: Luno
  Can't build InfiniTime Anonymous1 1 1,352 01-25-2023, 01:49 AM
Last Post: matthewfelgate
  error when try to build infinitime 1.10 gy145 2 2,047 07-08-2022, 08:23 PM
Last Post: gy145
  Daemon and go library to interact with InfiniTime on Linux Arsen6331 0 1,834 08-21-2021, 10:32 AM
Last Post: Arsen6331
  Build Infinitime Sources aemkai 4 4,843 08-01-2021, 01:41 PM
Last Post: JF002
Information InfiniTime Default Face USA Mod - No longer supported The3DmaN 1 3,156 02-25-2021, 03:51 PM
Last Post: The3DmaN
