Problem with updates: Repository 'Debian bookworm' changed its 'non-free component'
Hi guys,
I seem to have a problem with updating Mobian:
Whenever I try to update it, it says:
All packages are up to date.
N: Repository 'Debian bookworm' changed its 'non-free component' value from 'non-free' to 'non-free non-free-firmware'
N: More information about this can be found online in the Release notes at: https://www.debian.org/releases/bookworm/arm64/release-notes/ch-information.html#non-free-split
Does anybody know what I have to do in order to change the repository settings (if that's the problem) so that I get updates again?
Best,
A
Change (or add) non-free-firmware to /etc/apt/sources.list (as described by the mentioned link).
Thank you!
But what exactly do I have to paste into /etc/apt/sources.list in order to get updates again?
Just replace 'non-free' with 'non-free-firmware'
Thank you!
I changed the entry from
deb https://deb.debian.org/debian bookworm main
to
deb https://deb.debian.org/debian bookworm main non-free non-free-firmware
This has changed things, but instead of getting the zillion packages (that ought to be expected after weeks without upgrades)  it looks like this:
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://repo.mobian.org bookworm InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Anything I can do in order to get upgrades again?
(08-31-2023, 08:16 AM)Anna Wrote: I changed the entry from
to
It seems everything is actually working as expected.
Debian Bookworm = Debian Stable (currently), which means updates aren't as often as f.e. Stable does not get new upstream versions, only fixes to (serious) bugs applied to the version in Stable.
AFAICT the 12.1 point release was on 22nd July and the 12.2 point release is scheduled for 7th October at which point you should get a bunch of updated packages.
This is a feature, not a bug ;-)
But you should add the following line to get security updates:
deb http://security.debian.org/debian-security bookworm-security main non-free non-free-firmware
Those updates could come in at any time when a security issue is found (and fixed).
(08-31-2023, 08:42 AM)diederik Wrote: But you should add the following line to get security updates:
Done, thank you!
https://blog.mobian.org/posts/2023/03/11...-firmware/
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,639 Yesterday, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,012 04-10-2024, 10:02 AM
Last Post: diederik
  No volume control after latest updates Zebulon Walton 19 7,373 09-08-2023, 08:28 AM
Last Post: jessencan
  Haven't seen updates in a while Zebulon Walton 3 1,292 06-24-2023, 04:29 PM
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 2,946 06-06-2023, 06:36 AM
Last Post: freelectro
  Debian bookworm security repo user641 2 1,623 02-17-2023, 01:12 AM
Last Post: user641
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,247 12-22-2022, 07:10 PM
Last Post: acid andy
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 9,083 10-14-2022, 05:38 PM
Last Post: Krafter
  Wifi issue since last update and held back updates goku499 11 5,451 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Bookworm Satellite Navigation biketool 7 3,307 09-02-2022, 01:42 PM
Last Post: vortex
