Sanity check on spliced charger
I think that's beyond my current skills to modify charge controller on pbp
Yeah idk... one of those things obsess over, does it matter, reality...
A BSP uboot works better than tow-boot (maybe twice as good)
The kernel must be late5.7 or 5.8 or hexdumps's 5.9
mem as only setting in sleep.conf (SuspendState)
power button set to logout dialog
You might check out
https://github.com/hexdump0815
(05-09-2023, 07:06 PM)jcun4128 Wrote: I think that's beyond my current skills to modify charge controller on pbp
Check out the datasheet.  You can find a link to it in the wiki.  Unfortunately I'm not in a good situation for providing links, and I can't open the schematic at the moment.  But it looks like pin 13 on the charge controller, controls what voltage level it charges to.  It probably wont be difficult to modify that.
I'm not sure that you want to do this, anyway though.  That extra 20% of battery is very useful.  (But then I suppose it depends on your use case.)
:wq
[ SRA accepts you ]
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,900 10-21-2022, 07:57 AM
Last Post: dachalife
  Blinking red light for charger, no power-on bifo 11 13,799 11-30-2021, 01:37 PM
  USB fast charger HelpMyBatteryIsDraining 1 2,190 06-14-2021, 09:44 PM
Question Charger not included? fnl 8 9,493 01-16-2020, 09:46 PM
Last Post: chip ling
  Is it safe to use a charger with more than 3A output? Obikawa 8 9,471 01-14-2020, 02:32 PM
Last Post: zaius
