fully functional keyboard with Debian/Mobian
I had a fully functional keyboard under Arch/Monjaro w/
linux-image-5.17-sunxi64 using Megi's tutorial, but not having any luck w/
Megi's Debian/Mobian tut using the userland driver and vmlinuz-6.1-sunx64.
The userland driver doesn't seem to do anything, and loading the i2c-dev
module kills the native keyboard support. 'ppkb-i2c-inputd.service' shows up
in '>systemctl status' as enabled, but fails cause it 'can't find /dev/i2c-2
device', wh/ looks like a clue, but I read that those are loaded at boot time
and manually creating one doesn't seem like the solution.
I've also tried 'https://wiki.mobian.org/ppaccessories'.
I read that a fully functional keyboard w/ Debian/Mobian has been achieved
(year+ old reports and maybe a different kernel), yet it eludes me.
Soliciting suggestions/clues.
(02-09-2023, 07:07 AM)wigan Wrote: I had a fully functional keyboard under Arch/Monjaro w/
Update:
Referring to 'https://wiki.mobian.org/ppaccessories' above, the Automatic
Settings at the top didn't do anything, but adding 'export
XKB_DEFAULT_MODEL=ppkb' to ~/.profile (in the Symbol Keys section toward the
bottom) activated the top row symbols.  You'll need to go into 'settings >
keyboard > Alternative Character Key' and choose a key to use w/ numbers 1-10
to bring them up (the 'L3 key'?).
And disable the virtual keyboard in...
  Settings > Accessibility > Screen keyboard
  This doesn't stick between boots, but it's not much trouble, and it saves
  you from having to remember to reactivate it before removing the fon from
  the keyboard and not have a way to input.
Any clues on how to access the console??
  keyboard case charging but not typing new2pinephone 18 6,043 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 11,074 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 457 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,312 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 481 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,307 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 550 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 648 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,074 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 884 10-11-2023, 09:03 AM
Last Post: elof
