My short experience with Manjaro Plasma Mobile
A lot of the issues you were seeing are because you were using an ancient version of Manjaro Plasma Mobile that was never updated.
As for the update failing: Discover does not work properly on Manjaro, use pamac-gtk with pamac-mobile-integration if you want a GUI (though that will work properly on Plasma Mobile only if you have at least the 2022-02-09 stable update with KWin 5.25.5, it works fine now though) or just use the pacman or pamac CLI.
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,621 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 596 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,520 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,607 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 815 04-25-2023, 09:49 AM
Last Post: jakfish
  gnome-mobile dev Uturn 1 1,121 02-22-2023, 03:37 AM
Last Post: acrux
  Can't install Manjaro thorensjubilee 1 1,034 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 4,918 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,588 11-22-2022, 05:00 PM
Last Post: Chief
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,075 10-10-2022, 12:53 PM
Last Post: alaraajavamma
