Ox64 documentation mismatches
Hi guys,
  I am developing a board to use the Ox64 for a commercial application and while mapping out the planned pin usage and creating a KiCAD part I found a mismatch between the four documents I was referencing:
  • PINE64_Ox64-Schematic-202221007.pdf from the wiki.
  • PINE64_Ox64_placement-Bottom-202221007.pdf from the wiki.
  • BL808_DS_en_1.1(open).pdf from the wiki.
  • Ox64 Pin Assignments spreadsheet, probably from the original announcement blog.
The last one can probably be ignored as nothing on it matches anything else but if anyone see it posted anywhere they should probably have it pulled down to avoid confusion.
I have found five issues so far:
  1. Pin 4 on the schematic is labelled as GPIO12 but on the bottom placement is labelled as GP21.
  2. Pin 5 on the schematic is labelled as GPIO13 but on the bottom placement is labelled as GP31.
  3. Pin 6 on the schematic is labelled as GPIO41 but on the bottom placement is labelled as GP14.  There is no GPIO41 pin on the BL808C datasheet.
  4. Pin 7 on the schematic is labelled as GPIO40 but on the bottom placement is labelled as GP4.  There is no GPIO40 pin on the BL808C datasheet.
  5. Pin 12 on the schematic is labelled as GPIO20 but on the bottom placement is labelled as GP2.
I am guessing that:
  1. Pin 4 is actually GPIO12.
  2. Pin 5 is actually GPIO13.
  3. Pin 6 is possibly GPIO5.  Low confidence in this guess.
  4. Pin 7 is possibly GPIO4.  Low confidence in this guess.
  5. Pin 12 is actually GPIO20.
Couldn't find anywhere official to report these issues to so posting here in the hope the right people see this and can update the files on the wiki.
(11-28-2022, 02:43 AM)ukoda Wrote: Hi guys,
I am guessing that:
The current Ox64 info posted on wiki page is the prototype board version. The production version will be posted up on this week. The GPIO40 and GPIO41 are 32KHz xtal pins that can also be used as GPIO.
  [Article] Coding Ox64 BL808 SBC the Drag-n-Drop Way lupyuen 3 551 04-02-2024, 07:38 AM
Last Post: Noahstorey
  [Article] QuickJS JavaScript Engine on a Real-Time Operating System (Ox64 + NuttX) lupyuen 0 321 02-17-2024, 07:24 PM
Last Post: lupyuen
  [Article] Emulate Ox64 BL808 in the Web Browser: Experiments with TinyEMU lupyuen 3 550 02-17-2024, 06:53 PM
  [Article] Automated Testing with Ox64 BL808 Emulator (Apache NuttX RTOS) lupyuen 0 314 02-16-2024, 06:54 PM
Last Post: lupyuen
  Has anyone successfully flashed an Ox64 (128Mb) from linux? slondr 3 1,941 02-12-2024, 12:50 AM
Last Post: Pavlos1
  [Article] Nim on a Real-Time Operating System: Apache NuttX RTOS + Ox64 BL808 SBC lupyuen 2 627 01-05-2024, 12:27 AM
Last Post: lupyuen
  [Article] $8 RISC-V SBC on a Real-Time Operating System: Ox64 + NuttX lupyuen 0 496 12-17-2023, 02:27 AM
Last Post: lupyuen
  [Article] Fixed the UART Interrupt and Platform-Level Interrupt Controller (Ox64) lupyuen 0 507 12-09-2023, 05:24 PM
Last Post: lupyuen
  [Article] RISC-V Ox64 BL808: UART Interrupt and Platform-Level Interrupt Controller lupyuen 1 591 12-03-2023, 04:24 AM
Last Post: WhiteHexagon
  [Article] RISC-V Ox64 BL808 SBC: NuttX Apps and Initial RAM Disk lupyuen 2 678 11-25-2023, 06:42 PM
Last Post: lupyuen
