no sdcard boot and manjaro update failed
Hi there,
I received my pinephone few days ago and tried to update it (from UI, not ssh). ... It failed ...
Now I get the same big 'K' at start and nothing happens.
I'm not able to boot from sdcard. I tried two differents sdcards with manjaro image and jumpstart but pinephone doesn't boot anything else than the emmc.
I tried long press action on start button or other things seen on youtube or documentation but can't go further ...
I've understood there could be problems with full discharging battery also but I don't know if it's the case ... I don't think so but I'm not sure ...
Could some give some help please ?
(11-25-2022, 04:33 AM)Gwen Wrote: Hi there,
You're likely experiencing two issues at the same time here:
* The pre-installed OS got corrupted or the battery is drained
* The microSD card isn't flashed or inserted correctly
Jumpdrive will boot even with a drained battery, so it's likely that the microSD card isn't flashed or inserted correctly. Please write the exact (!) command and filename you used to flash the microSD card and if you inserted the microSD card in the top or the bottom slot (top slot is correct).
Thx for your answer.
It seems it was a problem with the command I used to burn the image on sdcard.
This is the exact command that succeded and permited me to go further :
xz --decompress --stdout /home/YourName/YourFolder/20221123-0417-postmarketOS-v22.06-phosh-18-pine64-pinephone-installer.img.xz | dd of=/dev/mmcblk0 bs=4M status=progress && sync && sync
All my tries with 'dd' failed.
Battery doesn't seem to be a problem anymore.
I was a bit scary about performances and usability for first to days playing with it but I use it in 'production' now since another two days
and it's really great device. (loved to be able to ssh in it and backup it as my other computers)
... I'm now trying to found good gps client app ... tried gnome-maps and osmscout/pure-maps for now ... but it's another story ...
Thx again. Have a nice day ! o/
(11-27-2022, 04:40 AM)Gwen Wrote: Hi,
Great. Feel free to let us know the exact dd commands which failed, then we can have a look what the issue was. One of the most common issues is that the img file in the xz archive isn't decompressed prior to flashing. The command you mentioned does the decompressing and pipes the output into dd.
  Pinephone boot. Richy_T 2 63 11 hours ago
Last Post: zetabeta
  PinePhone - boot from microSD laserpyramid 9 838 05-03-2024, 10:09 AM
Last Post: laserpyramid
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 283 04-02-2024, 11:50 AM
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,919 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  Mobian PIN changed after update! Mwo87 21 18,018 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,343 08-28-2023, 11:38 AM
Last Post: fxc
  Pinephone won't boot. spha 12 2,877 08-20-2023, 02:44 AM
Last Post: spha
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 0 650 07-13-2023, 02:39 PM
Last Post: jakfish
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,519 05-10-2023, 03:31 AM
Last Post: fxc
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 246,395 03-05-2023, 11:04 AM
Last Post: Eugo
