Cannot Boot From SD Card
I recently got a PineBook Pro and wanted to try a different OS.  I downloaded and flashed Armbian and TwisterOS images to micro SD cards, but I cannot boot from them.  When I power on the PB with the micro SD card inserted, the screen is blank and the power light blinks about once per second.  Is there something else I need to do to?  I feel like there's something obvious I am missing.
This should be a "sticky" somewhere.
The version of Manjaru that comes pre-installed on the 2022 Pinebooks Pro, includes a U-boot that does not allow booting from micro-SD card.
The ways to resolve this are
1) replace the U-boot on the eMMC with a different one, or possibly Tow-boot
2) wipe out the eMMC and install a different operating system on it.
3) install Tow-boot to SPI ROM (I do not actually recommend this, but it can be done, apparently).
4) disable the eMMC
:wq
(10-28-2022, 06:27 PM)KC9UDX Wrote: This should be a "sticky" somewhere.
4) disable the eMMC
Thanks for the reply!  I was able to install Tow-boot to the SPI Flash by following their directions and that gives me a boot menu.  However, I had to disable the eMMC first.
This was helpful!
4) disable the eMMC
Where are the HOWTOs for options 1-3?
(11-12-2022, 01:06 AM)jazzhands Wrote: This was helpful!
Thanks.
Hopefully you can find everything here: https://forum.pine64.org/forumdisplay.php?fid=117
That is where all the Pinebook Pro tutorials are supposed to be.  Except for using Tow-boot, I have been doing these things the hard way since the early days of the PBP, and I just muddle my way through every time.
:wq
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 1,376 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 1,948 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 28,643 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 17,885 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 11,917 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,073 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,318 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,965 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 8,479 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,567 01-16-2024, 09:17 AM
Last Post: jbradley419
