Installing Debian using files only from debian.org and encrypted root filesystem
I did the following, the pinebook pro would boot to into debian installer, and the install completed successfully but after install, the pinebook pro would no longer boot.
wget https://d-i.debian.org/daily-images/arm6...399.img.gz
wget https://d-i.debian.org/daily-images/arm6...ion.img.gz
zcat firmware.pinebook-pro-rk3399.img.gz partition.img.gz > final.img
I used "dd" to copy final.img to my eMMC adapter with eMMC module attached.
I reinserted the eMMC module into the pinebook pro and the pinebook pro was able to boot from it.
I was able to complete the install but the pinebook pro would not boot after the installer completed.
I did an expert install and selected "Guided - use entire disk and setup encrypted LVM".
What more has to be done to make the pine book boot?
I am loking for specific instructions to do this myself.
Do I need to select manual partitioning?
I do not want to use Daniel Thompson's pinebook-pro-debian-installer because it is over two years old and no longer maintained.
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 319,590 05-12-2023, 06:09 AM
Last Post: korreckj328
  Partial boot after installing Manjaro on emmc regivanx 11 3,200 02-06-2023, 09:11 AM
  Steps for Installing Alternative OSes in 2022 jazzhands 8 2,808 11-15-2022, 09:39 AM
  Use SD to install new OS over pinebook debian Rudy558 9 10,751 09-25-2022, 01:19 AM
Last Post: jackwilson
  Main Stream Debian on Pinebook Pro ? bcnaz 4 3,603 08-22-2021, 09:11 AM
  Installing Archlinux try2bgr8 1 2,333 10-27-2020, 07:14 PM
  Audio with Debian GloriousCoffee 5 7,361 10-15-2020, 01:22 PM
Last Post: Mangled
  help on setting up debian (or ubuntu) on micro sd card pine76 2 8,787 09-17-2020, 05:10 PM
Last Post: bcnaz
  trouble with installing emacs Corey_R 1 2,497 09-14-2020, 08:24 PM
Last Post: carlosqueso
  Suspend with NVME not working - Default Debian appdev46 5 8,672 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
