Hey Phosh Folks !!
I'm hoping that the Phosh staff read these articles.
We really do need a 'disable onscreen keyboard' switch.
It could be located in the Phosh banner at the top with the other switches.
I have noted that Postmarket os KDE Plasma has a disable keyboard widget.
Just a suggestion that 10's of thousands would agree with I suppose?
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
I actually had a case where I needed such a widget - I entered point A and point B in maps and then the keyboard wouldn't go away, taking up about 40% of the screen. If I had a hammer...
You can add a shortcut to toggle the keyboard display. Not quite as good as having it integrated, but maybe enough to reduce the pain.
https://forum.pine64.org/showthread.php?tid=15902
(09-05-2022, 02:25 PM)wibble Wrote: You can add a shortcut to toggle the keyboard display. Not quite as good as having it integrated, but maybe enough to reduce the pain.
I'm constantly using the keyboard icon to shut it off with nearly each time I hit the enter button while using a bluetooth folding mini keyboard where the problem mainly exists. When I dock my device using mouse and keyboard there is no issue.
Actually most of the time the keyboard icon is there, bottom right, and since the last update (which I managed to run yesterday, on Manjaro Phosh), it started working. Helped me this morning already.
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 0 633 07-13-2023, 02:39 PM
Last Post: jakfish
  Phosh - Tweaks and Customizing mikehenson 0 1,477 01-07-2023, 01:35 PM
Last Post: mikehenson
  No sms receival on Arch Phosh Pinephone pineuser0 2 1,382 10-09-2022, 08:55 AM
Last Post: treebeard
  Manjaro phosh no screen rotation sandspur 1 1,330 06-23-2022, 01:02 AM
Last Post: rapp
  Phosh - Squeekboard Layout mikehenson 0 1,202 01-21-2022, 10:53 PM
  Mobian updates for phosh steves 2 2,095 01-17-2022, 02:18 AM
Last Post: bcnaz
  PmOS Phosh: set compose and change layout stozi 3 2,487 09-24-2021, 07:41 AM
Last Post: ryo
  reduce Phosh bottom bar to corner icon? stozi 0 1,193 08-01-2021, 02:24 PM
Last Post: stozi
  Manjaro Phosh Beta 10...how to get button labels on Angelfish? INSTRUCTIONS WITHIN patrio 4 5,834 06-11-2021, 07:10 AM
Last Post: patrio
  Something that really bugs me in Phosh... mattpenn 1 2,197 02-08-2021, 08:38 PM
Last Post: The3DmaN
