Pinebook Pro won't boot
I was following the instructions on here https://nullr0ute.com/2021/05/fedora-on-...ebook-pro/, before halfway through the process of flashing u-boot, the screen went black, I assume because the battery ran out, so I plugged it in and now it won't boot up at all, the only feedback I get is the red dot from the charging cable being plugged in and the CPU is warm now. The power indicator on the keyboard no longer lights up. I've attempted to boot with the emmc both enabled and disabled, while on battery and while plugged in, and with the SD card inserted and removed, all to the same result. Is there anything I can do? I believe my spi flash is corrupted.
https://forum.pine64.org/showthread.php?tid=16361
(08-26-2022, 12:58 AM)wangyukunshan Wrote: https://forum.pine64.org/showthread.php?tid=16361
It didn't work for me and I'm not getting the power light when I try to turn it on like they do in this post
Same boat. Booted from SD flashed Manjaro Gnome distro for PbPro to emmc, never turned on again. eMMC switch did nothing. Power button useless. Reset did nothing. Battery or a/c bypass did nothing. Removed eMMC did nothing. Can't get it to power to even try booting from the SD card again.
Absolute trash. F Pine. F Pinebook Pro.
Your impatience and lack of understanding does not imply a bad product or company. I have seen reports of Pinebooks Pro being thrown in the trash. If you feel inclined to do that, please sell it in stead
It seems to me that it has gotten popular lately to flash U-boot (and alternatives) to SPI flash, making troubleshooting more difficult.
The biggest problem I find is making a micro-sd card that actually boots. Most of them that seem to boot rely on a working and cooperative U-boot on the eMMC. The second biggest problem is making sure the PBP is actually turned off after locking up from an errant boot. Then you have to make sure that SPI flash is erased (all zeroes) or is disabled.
I recently went through the list of bootable sd images in the wiki and the first one I could find that actually worked was DietPi, which I was able to use to wipe out the eMMC and recover the system. I would expect you could erase the SPI flash as well. Others have reported other operating system image that work. But I know the DietPi one works.
:wq
(09-03-2022, 07:43 PM)KC9UDX Wrote: I recently went through the list of bootable sd images in the wiki and the first one I could find that actually worked was DietPi, which I was able to use to wipe out the eMMC and recover the system.
All flashed w the same software on the same card? Ugh!
Any idea why it is so finicky? Is the uboot stuff missing from all the other images you tried?
(03-14-2023, 10:08 AM)Bram Wrote: All flashed w the same software on the same card? Ugh!
Yes.  No, I don't know why.   Frankly once I found one that worked, I didn't worry about it anymore.  I wouldn't have expected any to work when the first one didn't; except I had the exact same experience in 2020 when the list was different.  At that time, Chrome OS was the one that I got to work.
:wq
Question Printing and scanning documents with pinebook? Www 0 199 06-28-2025, 01:25 AM
Last Post: Www
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 0 59 06-28-2025, 01:04 AM
Last Post: Www
  Cant boot into an OS trashtendenz 4 1,545 06-26-2025, 02:20 AM
Last Post: samlevy0515
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 2,601 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  3 days in, slow/stuck or no boot. lgmpbp2 34 11,277 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 6,656 04-03-2025, 07:47 AM
Last Post: Tazdevl
  Pinebook pro bricked? michaelmoua 2 736 03-12-2025, 11:09 AM
  Use SD to install new OS over pinebook debian Rudy558 10 14,911 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 875 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 1,246 01-23-2025, 11:49 AM
Last Post: Surehand53
