Loving latest Mobian Update
One thing that got broken in this update (not sure if it comes from Mobian, though) is the megapixels app, which used to work better previously. Now it's still as sparse as before, but exits on any button, not taking a shot at all.
Here's what I get when I launch it from a terminal:
Found config file at /usr/share/megapixels/config/pine64,pinephone-1.2.ini
Adding camera rear from config
Adding camera front from config
(megapixels:4243): Gdk-WARNING **: 11:05:28.858: gdk_gl_context_set_required_version - GL context versions less than 3.2 are not supported.
Initialized OpenGL ES 2.0
Gsk:ERROR:../../../gsk/gl/gskglcommandqueue.c:1276:gsk_gl_command_queue_create_render_target: assertion failed (glCheckFramebufferStatus (GL_FRAMEBUFFER) == GL_FRAMEBUFFER_COMPLETE): (0x00008cd6 == 0x00008cd5)
Bail out! Gsk:ERROR:../../../gsk/gl/gskglcommandqueue.c:1276:gsk_gl_command_queue_create_render_target: assertion failed (glCheckFramebufferStatus (GL_FRAMEBUFFER) == GL_FRAMEBUFFER_COMPLETE): (0x00008cd6 == 0x00008cd5)
If anyone wants to use my reinstall guide it is here including a pre-problem installer link https://forum.pine64.org/showthread.php?tid=17205
It has the mandatory partition resize fix and also has the GPS function steps ready to copy/paste into SSH.
  atinout binaries for mobian/debian? NeutralGrey 2 82 10 hours ago
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,754 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,130 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 168 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,123 11-22-2023, 11:46 AM
Last Post: aLoop100o
  No volume control after latest updates Zebulon Walton 19 7,411 09-08-2023, 08:28 AM
Last Post: jessencan
  What actions needed to keep on mobian testing user641 3 1,902 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 664 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,145 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,962 07-09-2023, 01:37 AM
Last Post: vusra
