Impossible to minimize a window with Phosh
Exclamation
Hello
Since the latest update today, I can't minimize a window in Phosh. It drives the Pinephone very difficult to use. I don't even know a shortcut to minimize the current window. The widget in the bottom no longer works Sad
Do you know a solution or a workaround?
(08-16-2022, 03:07 PM)anonymous Wrote: Hello
Maybe connected to this?
Thank you for the suggestion. Actually, I've found the solution about an hour ago. Something seems to have been modified in the behavior of Phosh, you can no longer minimize the window by pressing the button in the bottom ^, you have to pull from the very bottom. Actually, it's much better now in my humble opinion, it avoids accidental presses which typically occurred when writing SMS in my case. Phosh is becoming more and more mature Smile
Yeah, the new Phosh is a big improvement in usability! Smile
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
(08-17-2022, 01:57 AM)anonymous Wrote: Thank you for the suggestion. Actually, I've found the solution about an hour ago. Something seems to have been modified in the behavior of Phosh, you can no longer minimize the window by pressing the button in the bottom ^, you have to pull from the very bottom. Actually, it's much better now in my humble opinion, it avoids accidental presses which typically occurred when writing SMS in my case. Phosh is becoming more and more mature Smile
I just upgraded my test system and saw that too.  The top bar is also a drag-down now instead of a click.  I think the change to the bottom bar was so that you wouldn't keep activating it accidentally while trying to press the spacebar on the OSK.  I suppose the top bar was then changed to be consistent.
Can you get to the desktop yet? lol
Cheers,
TRS-80
Protocols, not Platforms
(08-17-2022, 03:42 PM)TRS-80 Wrote: Can you get to the desktop yet?  lol
Me personally, I cannot. If I pull the rollet from the bottom, I cannot execute a second app, I cannot close the current app and if the rollet is pulled back down, it cannot be pulled up again. Never
Sounds very familiar to me, are you really sure it's not  https://forum.pine64.org/showthread.php?tid=17156  ?
  Auto start application on Phosh login Zebulon Walton 8 3,387 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Using sway along phosh fdlamotte 2 3,322 05-11-2023, 04:24 PM
Last Post: kabouik
Exclamation Impossible to login since the latest update anonymous 12 4,237 02-26-2023, 01:01 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,802 02-24-2023, 12:11 AM
Last Post: nexion
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,847 10-14-2022, 05:38 PM
Last Post: Krafter
  Phosh 0.20 beta on mobian Anthony1224 1 1,634 06-11-2022, 06:29 AM
  Transparent Phosh App Grid? arno_nuehm 1 1,763 03-15-2022, 06:00 AM
Last Post: dante404
  Phosh modem on/off effectiveness? Zebulon Walton 0 986 01-24-2022, 09:21 AM
  Updating Phosh from Gitlab ragreenburg 2 2,349 10-07-2021, 08:35 AM
Last Post: ragreenburg
  Seems like Phosh is in downgrade mode... ryo 17 16,247 06-01-2021, 06:22 PM
Last Post: ryo
