Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes!
My PinePhone became nearly unusable after apt upgrade today (mobian), because new phosh freezes and then crashes all the time IF you have disabled animations in phosh!
So if you have disabled them in the past (like I did), beware! Enable before updating!  Wink
Sources:
https://gitlab.gnome.org/World/Phosh/phosh/-/issues/818
https://wiki.mobian-project.org/doku.php...s-in-phosh
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
(08-16-2022, 01:06 PM)dante404 Wrote: My PinePhone became nearly unusable after apt upgrade today (mobian), because new phosh freezes and then crashes all the time IF you have disabled animations in phosh!
Sources:
 or after updating
 ezik
(08-17-2022, 03:35 AM)shulamy Wrote: or after updating
 ezik
Yeah, this is of course also possible (I re-enabled animations also after updating), but thats the 'harder' way... (you can't even open terminal and Firefox and switch between them to copy the command without a crash) Wink
And you have to know about this bug of course (that's the point of this thread).
On Mobian the animations can be turned on / off in the settings (Settings > Accessibility > Enable Animations).
Sources:
Thank you!
(08-18-2022, 04:35 AM)Pelecanus Wrote: On Mobian the animations can be turned on / off in the settings (Settings > Accessibility > Enable Animations).
Oh, cool, that has to be (relatively Wink ) new then - Thanks!
(08-18-2022, 07:33 AM)mikehenson Wrote: Thank you!
You're welcome Smile
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 1,023 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 14,435 03-31-2023, 04:17 AM
Last Post: Eugo
  Fedora + Phosh for PinePhone njha 74 132,802 12-12-2022, 10:19 PM
Last Post: wcdeich4@hotmail.com
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 2,287 09-14-2022, 01:19 AM
Last Post: dukla2000
  Phosh message notifications issue itstoughtofocus 2 2,735 08-15-2022, 06:39 AM
Last Post: nemsys
  Building an image with phosh liara 1 1,828 02-01-2022, 08:26 AM
Last Post: kqlnut
  More useful terminal key layout for phosh's squeekboard Boern 21 27,556 01-15-2022, 02:35 PM
Last Post: gilwood
  Phosh: Idles to Lockscreen Without Powering Off Display Merc 1 1,982 11-01-2021, 09:00 AM
Last Post: e1337
  Phosh - config within Settings does not save after reboot antitheos 0 1,447 09-24-2021, 04:30 PM
Last Post: antitheos
  Create a Phosh App in 10 Minutes TRS-80 2 2,665 08-21-2021, 10:02 PM
Last Post: TRS-80
