Phosh - config within Settings does not save after reboot
Hey guys and gals, this is my first post on the forums. I decided to ask around about a small issue I've got to save some time. Hope somebody knows the right answer.  Big Grin
So, I've finally figured out how to get Gentoo Linux running on my pinephone. Everything works nicely, but I was wondering how to make the system have all the settings save after reboot. For instance, some stuff like the WiFi network last used gets saved, but other things like display scaling or starting up as Docked (as if HDMI is used) do not, and just most other things changed in the Settings configuration tool do not stay the same after I reboot.
I assume this has something to do with Phosh or perhaps file access, but I'm not sure what is the problem. While not a big deal really, I'd still like to know how have these things work as intended. Thank you. Undecided
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 968 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 14,276 03-31-2023, 04:17 AM
Last Post: Eugo
  Fedora + Phosh for PinePhone njha 74 131,385 12-12-2022, 10:19 PM
Last Post: wcdeich4@hotmail.com
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 2,247 09-14-2022, 01:19 AM
Last Post: dukla2000
  Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes! dante404 5 3,261 08-18-2022, 02:03 PM
Last Post: dante404
  Phosh message notifications issue itstoughtofocus 2 2,709 08-15-2022, 06:39 AM
Last Post: nemsys
  Building an image with phosh liara 1 1,808 02-01-2022, 08:26 AM
Last Post: kqlnut
  More useful terminal key layout for phosh's squeekboard Boern 21 27,318 01-15-2022, 02:35 PM
Last Post: gilwood
  Phosh: Idles to Lockscreen Without Powering Off Display Merc 1 1,957 11-01-2021, 09:00 AM
Last Post: e1337
  Create a Phosh App in 10 Minutes TRS-80 2 2,634 08-21-2021, 10:02 PM
Last Post: TRS-80
