Can't connect to cellular network
I have an Airvoice SIM card* I've been trying to get to connect, but it's not working. NetworkManager seems to detect it properly and lists the correct SIM ID and even reports that the carrier is AT&T. I've tried using both "reseller" (no quotes) and "NXTGENPHONE" (no quotes) as the APN, but it never successfully connects. Here is some of my journalctl output matching /modem/i:
Failure mode 1: roaming-in-location-area-not-allowed
eg25-manager[2963]: GNSS assistance upload step (2/9): disabling GNSS engine through ModemManager
ModemManager[3180]: <info>  [modem0] simple connect started...
ModemManager[3180]: <info>  [modem0] simple connect state (4/8): wait to get fully enabled
ModemManager[3180]: <info>  [modem0] simple connect state (5/8): register                                            ModemManager[3180]: <warn>  [modem0] network reject indication received
ModemManager[3180]: <warn>  [modem0]   service domain: ps
ModemManager[3180]: <warn>  [modem0]   radio interface: umts
ModemManager[3180]: <warn>  [modem0]   reject cause: roaming-in-location-area-not-allowed                            ModemManager[3180]: <warn>  [modem0] network reject indication received
ModemManager[3180]: <warn>  [modem0]   service domain: cs
eg25-manager[2963]: Modem is up for 120 seconds and fully ready
Failure mode 2: no-suitable-cells-in-location-area
NetworkManager[3086]: <warn>  [1655592789.5434] modem-broadband[cdc-wdm0]: failed to connect modem: Network timeout
ModemManager[3180]: <warn>  [modem0]   service domain: cs-ps
ModemManager[3180]: <warn>  [modem0]   radio interface: lte
ModemManager[3180]: <warn>  [modem0]   reject cause: no-suitable-cells-in-location-area
Failure mode 3: plmn-not-allowed
ModemManager[3180]: <warn>  [modem0]   reject cause: plmn-not-allowed
Failure mode 4: No MCC/MNC or operator id:
ModemManager[3180]: <info>  [modem0] 3GPP registration state changed (idle -> searching)
ModemManager[3180]: <info>  [modem0] state changed (enabled -> searching)
ModemManager[3180]: <warn>  [modem0] couldn't load operator code: Current operator MCC/MNC is still unknown
ModemManager[3180]: <warn>  [modem0] couldn't load operator name: Current operator id is still unknown
NetworkManager[3086]: <info>  [1655594076.4347] modem["cdc-wdm0"]: modem state changed, 'enabled' --> 'searching' (reason: unknown)
modem-daemon[3725]: kf.modemmanagerqt: Unknown Mobile Country Code: 0
kscreenlocker_greet[3475]: kf.modemmanagerqt: Unknown Mobile Country Code: 0
plasmashell[3548]: kf.modemmanagerqt: Unknown Mobile Country Code: 0
ModemManager[3180]: <info>  [modem0] 3GPP registration state changed (searching -> idle)
  1. Do I need to issue modem commands manually to troubleshoot/fix this? I don't know how to do this, having relied on NM/MM so far; if it is, what's the best way to do this?
  2. Am I just not in the service area? I somewhat doubt this because I'm in a relatively densely populated area, but what I can understand from searching the reject causes suggests this might be the case. (I'm reluctant to switch to other providers mostly because I haven't found any prepaid plans less than 3x as expensive, but if it can't be avoided...)
* Compatibility unknown per the wiki
ADDENDUM:
Per this thread, it appears AT&T is no longer a viable carrier for PinePhones: https://forum.pine64.org/showthread.php?tid=15988
  How To Share The External MicroSD Folders and Files On A Network? pinephoneuser22 5 1,634 02-10-2024, 08:47 AM
Last Post: jakfish
  New Zealand network providers mobile data Linux2thabone 3 3,300 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US cellular service (as I understand it as of post date) freebsd 17 9,298 07-23-2023, 04:57 PM
Last Post: kb-zealot
  USCellular network rnelsen 2 1,586 05-29-2023, 07:03 PM
Last Post: rocket2nfinity
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,251 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  Waydroid does not connect to VPN t2moo 0 1,196 05-01-2022, 02:01 PM
Last Post: t2moo
  Wifi doesn't see 5 GHz network lsitongia 5 4,567 03-02-2021, 08:45 AM
Last Post: dukla2000
  no connect to wifi on first startup derbaertigefrytz 1 1,848 02-12-2021, 08:37 AM
Last Post: derbaertigefrytz
  No sms texts on concumer cellular sim card tckosvic 2 2,468 02-09-2021, 02:05 PM
Last Post: tckosvic
Tongue New Pine64 Phone UBports Edition Can't Connect to Wifi/Doesn't Charge blindbutnotblind78 1 2,573 12-02-2020, 08:42 PM
Last Post: evilbunny
