No sms texts on concumer cellular sim card
manjaro arm with kde plasma, just received.
Put in Consumer Cellular sim card.  Phone seems to work ok in limited test.
Another story with text messages.  In Phonebook if I try text message the chats program starts up and says that I need to activate a new account in preferences.  There is a preferences in the chats menu icon that says preferences but it does nothing.
If I go to Accounts in Settings, there is no option for consumer cellular and no active option to add one.  Looks like accounts available are :
ownCloud
Nextcloud
google
Is there another sms text app?  Or is my CC sim card only going to make phone calls.
thanks for any insights you may have.
tom kosvic
I solved my own problem when I found reference to "spacebar" as being an sms app. It works but it is really clunky.
Anyone recommend another sms app that uses sim card not internet?
Found solution when I saw that spacebar was an sms app. It does sms chatting. Uses the consumer cellular sim card. Looks like it works but clunky app.
Anyone know of a beefier sms messaging app for pinephone? Keeps threads organized by contact, for example.
  install iso from sd card to emmc aular 2 171 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 791 01-09-2024, 07:02 PM
Last Post: britelite
  US cellular service (as I understand it as of post date) freebsd 17 8,864 07-23-2023, 04:57 PM
Last Post: kb-zealot
  pinephone no longer receiving calls or texts jyoung 3 1,693 07-16-2023, 10:05 PM
Last Post: jyoung
  SD Card has wrong capacity AndyM 11 2,127 06-11-2023, 12:30 AM
Last Post: AndyM
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,123 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  Device Unable To Read MicroSD Card _radv_ 19 5,683 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 1,364 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 1,871 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,307 11-23-2022, 05:19 AM
Last Post: _radv_
