Multi usb-c adapter from Aliexpress?
We finally managed to run LibreOffice on the PinePhone and to control it with a Bluetooth mouse and a Bluetoth keyboard:
https://forum.pine64.org/showthread.php?tid=16614
Martijn Braam wrote here in the forum about another usb-c apapter with VGA output:
«In theory any dock that uses usb-c displayport alt-mode for the video ports should work (which most are). The usb3.0 is a bit useless since the usb connection on the PinePhone is only 2.0. «
We bought a USB C Hub 8 In 1 Type C 3.1 To 4K HDMI Adapter with RJ45 SD/TF Card Reader PD Fast Charge for MacBook Notebook Laptop Computer for 20 USD on Aliexpress, shipping included:
https://www.aliexpress.com/item/10050033...pt=glo2deu
We connected the adapter to the Pinehone. We plugged in an usb mouse, worked, an usb-keyboard, did not work, another usb keyboard did not work either, a HDMI monitor, did not work.
Does someone have any ideas how to make the missing components work?
update 13.6.22
- usb mouse is working
- usb keyboard is working
- powering the phone when usb power is provided is not working
- HDMI is still not working, although we removed the backcover over the phone as recommended here in the forum
  Best charging adapter Regula 1 2,803 03-14-2021, 03:22 PM
Last Post: Regula
  Multi USB Hub, with HDMI VGA and PD-port. Robert_pinephone 13 16,036 02-24-2020, 09:42 PM
Last Post: whistlepig33
