SSH from Windows PC into PinePhone?
#21
I saw that my top thread in the Pine64 forum was about «Bluetooth low energy & ANT+ sports sensors Pinephone distro?»:
https://forum.pine64.org/showthread.php?tid=10172
It had 28,700 views, but I suppose 28,700 viewers where disappointed, since altough I am highly interested in this topic, i did not get it to work since several years.
The Rasperri ANT+ which reads out sensor data from a Rasperri PI with ANT+ stick was developed on June 19, 2014 by Johannes Bader, a former PhD student from ETH Swiss Federal Institute of Technology in Zurich. It seems that a PhD in computer science is requred to read out sensor data from a Garmin watch in real-time.
Is also a PhD in computer science required to connect from a Windows PC to a PinePhone?
We made another trial following the instruction of wibble. We use PostmarketOS posh.
sudo apk add wayvnc
wayvnc -r 0.0.0.0 to listen on all the phone s IP adresses
On Tiger VNC viewer on the Windows PC, whe entered in the VNC server field of VNC viewer:
192.168.1.103:5900
where 192.168.1.103 is the ip adress of the phone and 5900 is the port wibble suggested
Whe get a Tiger VNC error message:
connection to 192.168.1.103:5900 failed.
Unable to connect socket. A connection trial failed, since the partner did not react, time out, the connection was faulty or the host did not react (10060).
We had an error message with TigerVNC. It was a  Connection refused/timed out error and is already known:
https://wiki.postmarketos.org/wiki/VNC#Troubleshooting
we had to enter:
apk add postmarketos-config-nftables-vncserver
service nftables restart
Then, it was possible to connect with  TigerVNC on a Windows PC to a Pinephone. What we can say after a first test:
- The Pinephone screen is mirrored fine
- The Windows mouse always worked fine, and showed up on the HDMI screen and on the Pinephone
- The Windows keyboard sometimes worked, sometimes did not work
- A test with the Gnome editor worked fine to write some text
with LibreOffice:
- Sometimes it was possible to drop down the menus with the PC mouse, sometimes not
- Sometimes the PC keyboard worked, sometimes not
- The PinePhone keyboard sometimes worked with LibreOffice, sometimes not
- When we installed LibreOffice on the PinePhone, it was possible to connect a Cap Clip Bluetooth mouse, write a file, drop down the menu and save the file.
- When connected to a Windows PC, whe had to restart the phone several times, sometimes, the menu worked, sometimes the keyboard worked.
- To save a file via keyboard and mouse on the HDMI monitor worked, but it was tricky.
  PinePhone - boot from microSD laserpyramid 7 584 Yesterday, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 354 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 240 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,177 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,803 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 612 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,373 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 501 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,707 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,974 12-04-2023, 02:14 AM
Last Post: Peter Gamma
