Instructions to change the IMEI
Wink
The other thread was closed before I had a chance to respond, so I'm just going to leave this here instead.
This works on the PinePhone Pro (Explorer). I have not tested on other devices. This works on the Quectel EG25-G modem.
FYI, I'm using Mobian, so you have to stop the modem-manager first or it will cause a conflict with minicom (terminal suddenly stops responding).
This feature is NOT documented in the PDF from Quectel, but it still works.
In a console:
systemctl stop ModemManager.service
Now you can run minicom without it hanging.
minicom -b 115200 -D /dev/ttyUSB2
Inside minicom, to get your current IMEI:
AT+CGSN
860195057712345
To change your IMEI:
AT+EGMR=1,7,"860195057754321"
OK
You can confirm it changed by running:
AT+CGSN
860195057754321
That's it.
  Screen Replacement Instructions erikkugel 5 11,003 02-24-2025, 06:55 AM
Last Post: anonymous
  FIXED-Newer ver of EC25 Modems, FOSS FW upgr breaks funct- repair FW and IMEI rebuild biketool 4 6,828 10-16-2024, 01:37 AM
  Are there instructions on updating V1.2a to V1.2b? stozi 4 6,649 07-05-2022, 05:20 AM
Last Post: stozi
Wink Pinephone IMEI changing info: do you think its OK for a Wiki? mikeb 28 52,092 05-28-2022, 10:49 AM
Last Post: fxc
  LCD panel replacement instructions mob 2 4,443 09-13-2021, 05:11 PM
Last Post: mob
  Battery/wifi problems every time I take the battery out to change SIM or SD card BlunderingBushcraft 6 12,267 08-25-2020, 01:10 PM
Last Post: bcnaz
  No IMEI for Braveheart Pinephone? curtvaughan 4 11,567 02-15-2020, 09:23 AM
Last Post: curtvaughan
